Question about HP DeskJet 842c InkJet Printer
Ink light is flashing but i have changed both cartridges
  • 32 Answers
You could try checking the printer ink receptical contacts for damage, or simply clean them, however you can often purchase a new printer that comes with ink, for cheaper then the cost of buying new ink for an existing printer.
Posted on Jul 03, 2009
I just got a rebuilt HP 5550 deskjet and hooked it up and the ink light is flashing the 2nd from the top.
See if there is an issue with one of the individual ink cartridges. Open the cover and allow the ink carriage to slide out. Then look at the lights on each cartridge to see if any are flashing.
Jan 31, 2018 | HP Office Equipment & Supplies
Ink light and on/off light flashing
Turn printer off for a few minutes then turn back on. If still flashing your cartridges may not be compatible.
Jul 17, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
Light flashes cartridge change, and change the cartridge and still flashing hp deskjet 920c
Make sure Orange protective cap (tape) has been removed from the bottom of the ink cartridge.
Either ink Cartridge is not installed properly or the function for detecting the ink level is disabled. Make sure that you install ink cartridges at correct position as indicated by the label on the print head holder. Press PUSH mark until ink cartridge click into the place.
Hope this will solve your problem.
Thanks for using Fixya.
Oct 21, 2010 | HP DeskJet 920c InkJet Printer
Need to change ink catrege help
Using the printer's control panel In some circumstances, you may need to replace an ink cartridge before it is empty.
If the fonth.gif ink out light is flashing or is on, replace the empty ink cartridge as described in Replacing an Empty Ink Cartridge.
To replace an ink cartridge before the fonth.gif ink out light flashes or the Status Monitor notifies you that the cartridge is empty, follow the instructions in this section.
r_caut.gif Caution: r_space.gif Do not remove the cartridge from the printer until you are ready to replace it with the other one.
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
r_2.gif Lower the output tray, then open the printer cover.
r_3.gif Press the fonth.gif ink button. The print head will move to the ink cartridge replacement position, and the fontp.gif power light will begin to flash.
r_space.gif r_note.gif Note: r_space.gif r_space.gif Do not press the fonth.gif ink button over three seconds. Otherwise the printer starts cleaning the print head.
Jun 13, 2010 | Epson Stylus CX6600 All-In-One InkJet...
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Change printer ink
Turn on the printer.
lower th epirnter's output tray, pull out the extension, and open the cover.
press and release the ink button.
if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
open the cartridge cover
Pinch the back tab of the empty cartridge as your left it out of the printer.
shake the ink cartridge 4 to 5 times while it is still in the package.
unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
repeal the procedure if more than one ink cartridge is out.
close the cartridge cover.
close the printer cover and press the ink button.
The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
Oct 10, 2008 | Epson Stylus C66 Photo InkJet Printer
Ink cartridge changed but computer will not recognize it has ink
Please try the following in an attempt to resolve this issue:
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button.
4. Open the CARTRIDGE COVER. Pinch the front and back tabs of the first cartridge, and remove it from the printer.
5. Place it back into the holder. Push it down gently into the holder, until the cartridge clicks into place.
6. Repeat steps 4-5 for each cartridge. Close the CARTRIDGE COVER once all of the necessary ink cartridges are re-seated.
7. Carefully lower the scanner, until it clicks into place
8. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
CAUTION: Never turn off the printer while the ON light is flashing, unless the printer hasn't moved or made noise for more than 5 minutes.
Aug 30, 2008 | Epson Stylus CX4200 All-In-One InkJet...
HP DeskJet 722c orange ink light flashing
Try changing the color cartridge. Also it is a good idea to clean the electrical contacts if it looks dirty.Use slightly damp(use water only) q-tips .
Hope this helps
Mar 27, 2008 | HP DeskJet 722c InkJet Printer
HP DeskJet 842c InkJet Printer Logo
296 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
