Question about Grilling
Not enough gas going to grill
I just put a new regulater and hose on my char broll grill and it did not change the grill tempture. It only heats to about 220 degrees. Any Idea?
    Scholar:
  • 127 Answers
Check the flexible hoses from the burner valves to the burner, as well as the orifices on the back of the valves where they attach to the flexible hoses. Spiders love to build webs there. Be sure the flexible tubes are fully seated on the back of the valves when you reassemble them to prevent a possible fire hazard.
Posted on Jul 07, 2009
How to replace regulator/hose/valve assembly on char-broil gas grill?
Follow the hose back to where it connects to the gas rail , and go from there , to see what has to come off if anything .
Apr 21, 2013 | Grilling
I have an old but trusty MasterFlavour Char Broil LP Gas BBQ 4635801 with built in Accuflex 451-05 5/16" hose (1 psi max) and standard US/Canadian regulator but I am now in the UK and want to know...
Yes, Susan, you will need to change the Hose/Regulator Assembly. You can probably pick one up at any store that sells gas grills and accessories. I suggest that you take your old one with you for comparison purposes., when you go to purchase one. In the USA, the assembly runs about $30.00.
Happy Grilling!!
Jul 05, 2011 | Char-Broil CharBroil Master Flame Gas...
The burners are not putting off good heat/flame. the temperature is oonly getting to around 300 degrees. what can be wrong?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 30, 2010 | Char-Broil Performance 463463006
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
May 17, 2010 | Weber Genesis Silver B Grill
Just bought new propane tank for my Charbroil grill. First two times it work perfectly. Very short cook times with only 2 out 4 burners on. Now the grill lights but only enough of a flow for a low heat....
Either you got short changes on gas or the regulator is not working properly. Check the tank to see if it is empty, if not then the regulator will need to be changed.
Nov 12, 2009 | Char-Broil CharBroil 4637318 Grill
My Char broil grill doesn't heat up enough, the flame is not as high as it used to be. Any ideas? thank you
try opening the tank really slowly. if you open it too fast the overfill protection devise inside the tank will restrict the gas flow. hope this helps.
Oct 06, 2009 | Char-Broil Grilling
New Char Broil gas grill heating issue
Did the kit come with NG orifices and did you use them.
Jun 23, 2009 | Grilling
Please help
have you cleaned the burners? if they are not clogged your regulater is the problem and should be replaced asap. don't use the grill until you have replaced the regulater if that is the problem.
Sep 01, 2008 | Char-Broil 7000 Quick Set Gas Grill
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
