FixYa.com
Tags:
Microsoft LifeCam VX-6000  Webcam
Driver not recognised (by 6 users)
posted by hairpulling on Nov 10, 2007
I have a Microsoft Lifecam VX6000 which was working perfectly fine until I did a Windows update on it. I believe it was the SP2 that was downloaded. I have tried to uninstall > reinstall, however it picks it up as a USB20 camera and when I specify the location for the driver, it states that the necessary software cannot be found. I have tried to install it from the CD as well as downloading the latest driver update from the Microsoft website. I used to have a Logitech Quickcam Express Cam (I heard that this may be what is affecting the functionality of my webcam since the SP2 update).
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Mosaya, posted on Jun 04, 2008
My lifecamvx6000 works fine with the instant messaging service but does not works with its software and also it gives error massege:lifecame,exehas stoped working.
Comment by Guest, posted on May 07, 2008
I have a Microsoft Life Cam VX 6000 webcam too, and it was working just fine I unpluged and when I plug it again the audio installs but the cam does not...it says can not install hardaware can nor find the software. This cam is expensive and MICROSOFT is quit.
Comment by Guest, posted on Apr 10, 2008
vx6000 was working fine then quit. tried all i know to to do. i get an initialization error message
Comment by Guest, posted on Apr 08, 2008
I have a Microsoft Life Cam VX 6000 webcam and it was working just fine I unpluged and when I plug it again the audio installs but the cam does not...it says can not install hardaware can nor find the software
Comment by Guest, posted on Apr 04, 2008
I have a Microsoft Lifecam VX6000 which was working perfectly fine until I turned on my pc today. It shows a new hardware found and it picks up a USB20 camera. I tried to intall it from the CD and when I specify the location for the driver to update the device, it states that the necessary software cannot be found. Where can i go to update this driver ? Or what else can be done to fix this problem?
Thanks in advice for you Help!
Best Solution
posted on Nov 10, 2007
Inappropriate (40)
peepnklown
Rank:Wiz Wiz
Rating: 84%, 169 votes
Usually, I have seen with most USB webcam, they want you to only plug in your webcam after the software ask you to plug in the webcam. If this is the case, uninstall and reinstall (but, do not plug in webcam until the software tells you to).
Rating Locked! (?) hairpulling has rated this solution as Inappropriate
Can you Help with these Web Cameras problems?
Microsoft LifeCam VX-6000 (68C-00001) Webcam
Lifecam VX-6000 will not...
I am on my second VX-6000 but... Answer This...
Video default
How do I change the default on... Answer This...
resolution
I have a microsoft VX-1000... Answer This...
installation issue
my VX6000 used to work on old... Answer This...
Microsoft webcam VX 6000. Buzz...
The webcam works fine, the... Answer This...
Repair Service
Find Web Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
