Question about Karcher PSI Electric Pressure Washer
My pressure washer seems to be leaking at the lance connection can anyone help?
  • 174 Answers
Take the lance off and look to see if there is a missing o-ring or maybe a crack
Posted on Jul 03, 2009
The washer is running but i do not get pressure
I had the same problem. Here are what I did to fixed it.
1. Ordered a O-ring kit from Amazon and put it on since there was a leak at the connection to the water gun (lance). It solved the leaking problem but the pressure was still low.
2. Then I took apart the water gun and back flush the water path. Once it is clean you should be able to see through by aiming it to a light. Any small particle of dirt blockage will cause side way mist and a lower pressure.
Hope it helps
Jul 18, 2015 | Garden
How do i fit a new lance to Challenge MH02-1610GO pressure washer
Just the lance or trigger gun! Best of luck to ya!
Sep 23, 2014 | Garden
Kodiak manual
www.ppe-pressure-washer-parts.com/kodiak-pressure-washer-parts
NOTE: We are not KODIAK or affiliated with them. We did not sell these Pressure Washersbut do offer some parts that will fit them.
As close as I could fine. A hard one.
May 20, 2014 | Garden
My washer makes a loud pulsing noise when not being used,as soon as I pull the trigger it works fine.
sounds like your unit has a bypass problem either needs adjustment or replaced
Oct 14, 2012 | Karcher Garden
When i connect my vario pressure lance to the gun it leaks like a sieve thus reduced pressure but when i fit my other accessories its ok???
It sounds like you have the vario lance set to low pressure or "mix". If you twist the end of the lance you can increase and decrease the pressure. The setting you have it on is for when you are applying detergent through the pressure washer hence why it is a wider low pressure jet.
please remember to thumbs up, thanks.
Mar 19, 2011 | Karcher Garden
Lost pressure
try this
dissconect hose and lance , and check for water flow through the machine , if theres none or just a trickle then you may have gunk in your inlet filter ( usually a small plastic gauze insert just where the water feed hose connects )
then start machine , check for high pressure flow ( you will see the difference )
its quite common for the nozzle on the lance to become blocked
if all this seems fine but the lance is vibrating then you have a blockage in one or more of your pump valves .
Nov 11, 2009 | Honda Pressure Washer PSI 3000
The high pressure lance has sprung a leak can i purchase a new one
If we're talking about a pressure washer, then yes, you can purchase a new lance. Companies usually sell replacement parts, and there are also after-market parts available. You didn't state the brand or model # of the pressure washer, and depending on the brand and model, you may be able to repair the leak. It may be a matter of a worn O ring. If you purchased the washer locally, go back to the store and ask for a repair kit or O ring (s). They will also have lances as well.
Was this helpful?
Aug 08, 2009 | PowerBase Car Audio & Video
PRESSURE WASHER DOESNT HAVE MUCH PRESSURE, MOTOR DOESNT EVEN KICK DOWN LIKE ITS UNDER LOAD
Make sure that the tip of the head is not damaged, or missing anything.
Sometimes, there can be a pressure leak from the tip of the lance, inhibiting the pump from kicking in properly.
Hope that helps.
Jul 28, 2009 | Honda Pressure Washer PSI 3000
Karcher PSI Electric Pressure Washer Logo
206 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
