Question about Hansol 730E 17" CRT Monitor
Problem in monitor the screen doesnot get full wide of it by control panel
When i use the control panel to chang the wide of the screen
the screen become narrow and wide but doesnot rich to the max. wide of it
ie. there is a larg blank area in the screen
  • 51 Answers
Assuming your running Windows as the operating system on your computer, go into Display Properties and set the refresh rate to something other than 60 hz or default. On my XP computer this can be done by right clicking on the desktop, clicking Properties -> Settings -> Advanced -> Monitor. Anything in the 70, 72, or 75 hz range should work fine. If this does not fix the problem and the monitor is out of warranty trash it and get another one.
Posted on Nov 10, 2007
How can i change AOC monitor to wide screen, menu bar does not highlight. I have three monitors and the one on display port is wide screen by itself.
go into the computer , control panel find the appearance and personalization section ans change the aspect ration of the screen there. don't forget to apply and save(ok) before leaving
Feb 13, 2015 | AOC Computers & Internet
How do I make the screen on my sanyo tv full- It has a black bar top and bottom
Your TV remote control (not the cable box remote control) would have to have a button that would allow the changing of the TV screen sizes. My Sony TV control has a button called, ' wide', and when pressed will change my screen to either, full, wide zoom, and zoom. Only zoom gets rid of the black bars on my TV. If no button, than the screen size will be determined by the broadcaster.
Feb 10, 2013 | Sanyo DP26640 LCD TV
Wide screen stretches all my photos
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Dec 09, 2011 | Samsung Computers & Internet
We have just bought an LG 23 inch monitor. Everything okay on it except for the proper resolution. The monitor no. is W2343T. I have put the resolution of 1920 x 1080 and frequency of 60 hertz on it as...
I think the problem is going to be in the Windows software, and not the settings on the monitor. Not sure which type of computer or which Windows you're running, but get into control panel, monitor settings and see what you can do. Windows help and support might be able to assist you.
Here's an excerpt from ncix.com:
Cons Clumsy front panel controls
Vertically, picture is no larger than my old 17"
May require video card upgrade for higher resolutions
Front panel illuminated power button is distracting
Summary Overall, I really like this monitor. But don't expect a size increase vertically over a 17" display. I actually lost half an inch. I prefer a 16:10 aspect ratio so I'm not actually using the full wide available. If you're like me you can save some change and go for the 2243.
Not sure if that will help, but there it is.
Here is the whole blog:
http://ncix.com/products/index.php?mode=productreviewread&product_id=37490
Not sure if this will help, but you might check it out:
http://www.sevenforums.com/graphic-cards/19981-cannot-display-1920-x-1080-a-2.html
Good luck, and hope this helps.
Sep 20, 2010 | LG Computers & Internet
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
Settings have been changed.
Change the resolution in your PC control panel/display settings tab.
Jun 08, 2010 | Acer 22" X223w LCD Monitor
With windows7 screen is small@1024/768 is ok if you use 1440/768 how can i use 1024/768 and get full screen 20 ' wide screen
Hello.
If you have a Wide screen monitor it can only (look good) in a Wide screen resolution such as 1440x768.
1024X768 is the lower resolution, and it is for normal screen (square) monitors, not for wide screen monitors.
You cannot get a full screen at 1024X768 resolution with a Wide Screen Monitor.
Hope that Helps.
Jan 29, 2010 | Evga N350 NVIDA 6600GT 128MB 128bit AGP8X...
Widescreen reset
Go to the control panel and click display and reset it the way you want it. You may have to do this everytime you play your game.
Apr 25, 2017 | 3G Technology GEM GL-822A/B 17" Flat Panel...
Hansol 730E 17" CRT Monitor Logo
280 people viewed this question
Top Hansol Computers & Internet Experts
k24674
Andre van Wyk
Andre van Wyk
Level 1 Expert
ray gallant
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
