Question about Black & Decker 7750 4 1/2'' Small Angle Grinder
I borrowed a B&D 7750 3 to cut off the legs on a wire shelf system. I would like to replace the grinding disc but it appears to need a special tool to remove the disc. Is that correct? The owner says he has nothing but can't remember how to remove the disc.
  • 285 Answers
Yes you need an angle grinder spanner/wrench. It is like a tool with two pins that fit in the holes of the grinder disc securing nut. You can see a picture of one here: http://images.toolspot.co.uk/Angle%20Grinder%20Accessories/Angle%20Grinder%20Spanner%20For%20412in.jpg
They do come in different sizes, but you can also buy adjustable ones. Your best bet is to take the grinder to the local hardware store, big box outlet or anywhere power tools are sold and they should have a grinder spanner to suit your grinder.
Posted on Jul 03, 2009
Adjustsettings on Oregon 511AX bench grinder
there is a nut and bolt that holds the little shelf below the grinding wheel. Loosen it and adjust the shelf or rest to within approximate ly1/8 inch of wheel for safety.
Nov 27, 2014 | Oregon 511ax 115-volt Bench-mount Chain...
How do you hook up a toggel switch?
are you planning on just trying to control 1 load, in a car? If so the switch simply will go in line with one of the wires. A single trow single pole means on & of for 1 wire In this case the Positive lead will get the switch. You will just have to cut the positive wires near where the switch is needed and connect each end to the switch. It may also be a 3 position single throw single pole (if it has 3 legs) then use one end leg and one connected to the center leg meaning it will be an on, off, on. This will cut the flow of voltage to the load on the positive wire the same as the 2 leg switch. If it's in you house with AC voltage it's advisable to use a switch that will cut voltage to both wires since AC will still shock you with only 1 wire. It remains live. That type of switch is referred to as a single throw double pole. Meaning on and off but has 4 legs coming off of it cutting voltage to both wires.
Apr 03, 2013 | Alpine MRD-M1000 Car Audio Amplifier
My JVC stereo doesn't play cd's anymore, still runs audio for tv, and radio. What is best, low price stereo option i can hook speakers up to and play cd's again?
The CD player might just need it's lens cleaning. Best way to do this is taking the top off and cleaning the lens with either Servisol Video 40 or CD lens cleaning fluid.
Mar 03, 2013 | JVC MXKB30 300W 3-Disc CD Shelf System...
Sony MHC-GZR888D : Error C 31 00 & tray not opening
Either its disc loading motor, or the loading belt has the fault. Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
Sometimes, the disc loading mechanism might need replacement. If so, contact the nearest authorised service center for Sony. The Sony disc loading mechanism can't be bought from open electronic spare part market.
May 31, 2012 | Sony MHC-881 Shelf System
I've got a B & D Pro 4247 Grinder and I need to change out the grinding wheel and use another (because of the material that I'm grinding)... but I don't know how to remove the wheel that's on the...
if you don't have a spanner wrench, I would find a punch and loosen the outer flange, but the spanner wrench is not that expensive to have in the future. the part number is 149645-00. let me know if you need more assistance
Feb 11, 2011 | Black & Decker 7750 4 1/2'' Small Angle...
I need replacement brushes for a B & D 7750 4.5" grinder and can't find a source. Any ideas? Thanks.
This is considered a throwaway tool when any internal parts break or wear out, including the brushes. It's usually cheaper to buy a new one as opposed to repairing one. If it's still within the warranty period, B&D will replace it or prorate the value depending on how long you've had it. The only replacement parts available for this grinder are the side handle, blade guard, the inner and outer flanges and spanner wrench.
Dec 18, 2010 | Black & Decker 7750 4 1/2'' Small Angle...
18 year old Beocenter 9300 CD won't play most CDs
cd unit unable to read disc,replace or try cleaning laser lens.cd clamper may be misaligned or faulty,check operation in service position(top up).
Dec 18, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
Error message No Disc
Unit has bad disk t-table motor
May 06, 2008 | JVC MX-J200 CD Shelf System
CD unit
Effectively, the loading me4chanism is out of timing. This unit needs to be rebuilt. Why it became out of time is not important or knowable really. This is not a repair I would attempt without the service manual as these units have a specific re-assembly sequence. That sequence insures that the gear timing is correct.
Good luck.
Dan
Mar 24, 2008 | Sony CMT-HP7 CD Shelf System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
Open Questions:
See all Black & Decker 7750 4 1/2'' Small Angle Grinder Questions
Black & Decker 7750 4 1/2'' Small Angle Grinder Logo
413 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
