Question about Martha Stewart Home Office Tyler Desk, Molasses Brown
I need three of these desk. Help
Also the Tyler file cabinet that rolls. Three as well
    New Friend:
    Problem Solver:
  • 11 Answers
Please refer this website for your needs Second hand office furniture Used office furniture
Posted on Mar 05, 2015
  • 2,119 Answers
Http://www1.macys.com/shop/furniture/home-office-furniture/Furniture_category,Sortby,Productsperpage/Desks,ORIGINAL,40?id=35422&edge=hybrid&cm_mmc=Google_DMA_Furniture-_-Furniture+-+Generic+-+Home+Office+Furniture+-+Mod+Broad_Office+Desks-_-48380724084_Broad-_-%2Bhome%20%2Boffice%20%2Bdesk_mkwid_s5MHUXXEp'dc_48380724084%7C-%7C5MHUXXEp
Posted on Sep 24, 2014
SOURCE:
How to clean Metal Filing Cabinets?
Metal filing cabinets are tricky to clean. Start by cleaning the exterior of the cabinet. Use clean water to clean the outer side with sponge. Remove the rust by applying navel jelly on them and remove it completely by clean cloth. Use fine sandpaper to remove the flakes and mineral spirits to get rid of the dust. At last paint the metal cabinet by spray paint or liquid paint.
Visit Fire Cabinets Direct Ireland for buying fireproof cabinets & chubb cabinets in online..
Mar 05, 2016 | Home Security
How do you take off the water pump
The drain pump on your model is inside the cabinet on the back left. You can remove the front panel by pressing in on two clips, located in the seam where the front meets the top of the washer,with a putty knife. You will also need to roll off the belt under the washer. Once you have the front panel off the pump is held in place by three screws that anchor it to the washer's base.
It should be part #35-6780 here's a link Drain Pump 35 6780
Hope that helps!
Aug 05, 2014 | Maytag PAV2300 Top Load Washer
Printer header path type 1, 2, and 4 prolem request for feeding back
If the media does not feed into the in-feed slot in the media cabinet, try the following:
  • Make sure both roller levers are lowered to open the in-feed slot.
  • Trim the leading edge of the paper so it does not get caught in the slot.
  • Insert the media evenly to avoid angles. Do not insert one corner and then the other.
    NOTE: A beep means that the printer has detected the media in the in-feed slot. The printer will only beep once in a load cycle, if media is removed and reloaded the printer may not beep again if the load process is not re-started through the front panel.
Media does not advance If the media does not advance far enough into the in-feed channel in the media cabinet, the paper is slipping and the rollers do not grip the media. Try the following:
  • The pre-tension might be applied incorrectly. Always apply pre-tension by turning the star screw on the left side of the spindle. Never apply tension by turning the media roll or the spindle disks.
  • Clean the rollers using the cleaning procedure.
  • If the media being used is heavy coated, try changing the media.
Media jam in the in-feed channel If there is a media jam in the in-feed channel, try the following:
  • Turn the multi-roll feeder off using the power isolator switch on the connector panel at the back.
  • Open the media cabinet doors and lower the roller lever on both sides.
  • Turn the spindle to pull the media out of the in-feed channel and to collect it back on to the roll.
  • If the media is blocked, place the spindle in the park position for better access to the in-feed channel, and then pull the media edges in a downwards direction on both sides.
  • If the media cannot be reached because the roll has finished and it has not been ejected from the front of the printer, open the rear cover and try to remove the media from the motion control assembly.
    NOTE: Do not insert media with crumpled or damaged edges, trim the media first.
  • Make sure the leading edge is trimmed straight.
  • Make sure there is even tension across the width of the media.
  • Make sure media is aligned (the same amount of media is fed across the width).
  • Apply pre-tension the media.
When the printer is going to be unattended for a long period of time, it is a good idea to load and unload each roll using the LOAD/UNLOAD commands from the front panel (if the media loading procedure was not completed when prompted by the printer). This will ensure that each roll of media loaded is correctly aligned and that the printer is capable of loading/unloading each roll when requested by the print jobs in the queue.
Media misaligned When a "Misaligned?? message is displayed, the printer unloads the media. Press ENTER to continue and the printer will display the "Ready for paper?? status message. Do the following:
  • Check for even tension across the width of the media. If there is less tension on one side than the other, then the media is not straight in the in-feed slot.
  • There is a hole on the right side of the in-feed slot. Make sure the edge of the media is aligned with the left side of this hole.
  • Lower the roller levers on both sides and adjust the media so that tension is even across the whole width. Turn the spindle disk quickly two or three times away from you and then two or three times in the opposite direction. This will help to create an even tension.
  • Lift the roller levers on both sides and try to load the media again.
If this does not solve the problem, remove the media from the in-feed slot and repeat the loading procedure. Make sure the roll is against the right hand spindle disk (fully inside the roll core), and do the same for the left hand spindle disk. The printer verifies correct alignment using the blue line on the right hand side of the printing area as a reference. Media does not unload correctly If the media does not fully unload from the in-feed channel in the media cabinet, check the following:
  • Maybe there is not enough pre-tension. Always apply pre-tension by turning the star screw on the left side of the spindle three or four times (or more if the spindle is on a low retainer bracket). Never apply tension by turning the media roll or the spindle disks.
  • The spring applying pressure on the retainer bracket is loose and the spindle is slipping in the retainer bracket. Turn the multi-roll feeder off and turn the retainer bracket screw one turn in a clockwise direction.
Partial or blank prints If the print is partial or blank, check the following:
  • Check the multi-roll configuration in the printer driver: Check that the Has Multi-Roll Feeder check box is selected.
  • Check default roll configuration: Check if a roll is installed for the roll configured as default. If a roll is not selected from the printer driver, the printer will try to print to the default roll, and if no identical roll is available, it will not print the job.
  • Check Productivity mode settings: If the mode is set to normal and the roll has finished, the job cannot be printed.
  • Check cable connection: Check that the printer and any network cables are securely connected to the printer. Make sure the parallel cable is connected between the multi-roll feeder and the printer and ensure that it is also firmly connected between the computer and the multi-roll feeder.
  • Check media configuration: Make sure the media rolls are configured correctly.
  • Check document file: When printing files that are generated with versions of printer drivers for printers without multi-roll feeders, the header section of some file formats already contains information on the media. In these files, roll or sheet information corresponds to roll 1 in the multi-roll feeder. These files will print to the Default Roll. HP advises that the top roll (roll 1) is used as the default.
Dec 09, 2010 | HP DesignJet 1050c plus InkJet Printer
Electric dryer heats properly and is still drying properly but makes a thumping noise while working.
More than likely this is a tub roller. Looks like a small tire and wheel. that the tub rolls on.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 31, 2010 | KitchenAid Dryers
Tv wont come on
<font size="4"> Any luck getting this fixed?Please let me know.Thank You very much!<br /> Tyler<br /></font>
Jan 03, 2010 | Akai LCT2785TA 27 in. LCD Television
Need to take body off kenmore washer
the end caps on your control panel should pop off
behind them you will see two screws
oce those are out roll the control up and over
now you will see two brass dogs holding the cabinet down you can pop those with a flat head
disconnect the door switch conecctor
and roll the cabinet tword you
Oct 09, 2009 | Kenmore 22422 Top Load Washer
My kenmore washing machine leaks water from somewhere underneath every time I use it. what can I do?
ctake of the cabinet ands inspect the machine while running to determine the leak area
two philips screws on the back or front corners
remove those and roll the controll board up and over
you will see two clips on the exch corner in back
pop those off,,,,, remeber how they are positioned
once those are off you will see a two wire connector
unplug that, and the top part jump with a peice of wire
no you can roll the cabinet forward and off,
now roll the control back and turn the machine on
you should be able to see where the water is now comming from
Oct 07, 2009 | Washing Machines
Kenmore kill switch
it's under the top panel, you must remove the two screws on the control panel (one on each side in the front lower corner of control panel), then roll the entire panel up and over the top on it's hinges. then there are two gold clips (one on each side) that loosen the back from the entire cabinet, stick a flat blade screwdriver in them and they will pop out. theres one plug with three wires in it going to the top re,ove it, then open the lid and grab the top panel and tilt to you about 30 degrees up and slide the whole cabinet away from the base and guts of the machine.
now you can access the lid switch to replace it.
Apr 01, 2008 | Washing Machines
Aculaser c100 colour printing problem
Is the problem on all three colors? Is it possible someone has cleaned the toner transfer rolls - they have some "iron filings" to help the distribution and transfer of the toner. If this is the case you need a replacement toner roll assembly.
Nov 02, 2007 | Epson Aculaser C1100 Printer
Martha Stewart Home Office Tyler Desk, Molasses Brown Logo
894 people viewed this question
Top Martha Stewart Home Office Furniture Experts
Tom Chichester
Marvin
Marvin
Are you a Martha Stewart Home Office Furniture Expert? Answer questions, earn points and help others
