Question about Refrigerators
The fan continuously runs except when the doors are open.
  • 854 Answers
This Link my help...
http://www.appliance411.com/faq/defrostproblem.shtml
Posted on Jul 03, 2009
Why does my cooling fan inside the refrigerator keep running?
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
Mar 05, 2015 | Refrigerators
Refrigator does not stop running
Jun 29, 2014 | Kenmore Refrigerators
Refrigerator runs constantly
May 17, 2014 | Samsung Refrigerators
Refer door left open overnite. can hear it running but fridge and freezer are not cold.and it has run all day. What can I do? .
the fan that blows air from freezer to fridge is probably frozen with ice from all the moist air when door was left open turn off unit and let defrost will see screws where fan is located to help fan defrost us hair drier to free fan when free enough to turn freely turn on unit and push door switches or close door and listen for fan to go on if goes on turn off unit and and continue to defrost till fan and duct [airway ]is clear of ice than turn on and let run -if fan doesnt go on have tested may have burnt out from trying to run while frozen up repair or replace fan and recheck unit good luck
Jun 27, 2011 | Kenmore 94499 Refrigerator
GE Profile 21 cu ft. goes continuously except upon defrost, "once a day" for about 30 minutes. Unit cools both on freezer side and refrigerator side (ice cream ok and milk ok). Repairman...
open the doors and feel the middle strip.if that's hot check the condenser fan to make sure it's running and clean out the coil in the back.pull out the machine,remove the bottom panel,on the right side you'll see the coil,with a shop vac vac off the coil and then put it on blow and blow out the coil,that's the only way to clean this kind of coil and make sure the fan is blowing back there.let me know what you find,also send the full model number,open the fridge door,look at the right wall near the ceiling and you should see the model number.
Jan 23, 2011 | GE Profile Side-By-Side Refrigerator with...
My Dacor DMT2420 fan, light and turtable motor run continuously when the door is open. I have unplugged the unit to reset it with no help, another on-line forum expert suggested checking the door switches...
If the cooling fan, light and turntable run continuously when the door is open, but not when it is closed, your secondary interlock (bottom door switch) is shorted (always on).
Even if it's shorted, the actuator button (usually red) will still move up and down when you open and close the door.
It will need a new door switch.
See the service manual here. See our file on door switches here.
Jan 04, 2010 | Dacor DMT2420SS Microwave Oven
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Sharp R1490 when door is open fan runs...
check door switches and control circuit.
Nov 20, 2007 | Sharp R-1490 Microwave Oven
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
