Question about Vacuums
Vacuum cleaner belt replacement (Boss 1359)
I need to replace the drive belt for this model but I don't have an owner's manual. Instructions or directions to where I can get a free download of the manual will help a great deal.
Thanks
Katharine
katharine@reedmace.com
  • 3 more comments
  • Anonymous Nov 20, 2007
  • Anonymous Dec 04, 2007
    how do i open the belt compartment?
  • Anonymous Dec 10, 2007
    I have no idea where to put the belt and how to get it tight.
  • jab3769 Dec 29, 2007
    I need to replace the "timing" belt on the Hoover Savvy Vacumm cleaner that is described as beltless...just moved and can't locate the instruciton manual can you direct me to the site to download the instruction manual for this U8185-900 Hoover Savvy?
  • Anonymous Oct 23, 2008
    Uuughh, same here, the belt seems too big for the spot that it belongs, please help I need it desperately.
SOURCE: bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Posted on Nov 10, 2007
reddevil6
  • 1673 Answers
SOURCE: need to download users manual/how to install brush belt
http://bissell.com/images/UserGuides/7901.pdf
same as 8901
Posted on Jan 17, 2008
reddevil6
  • 1673 Answers
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
It should be a standard Eureka U belt. That number you have is not a good number. Most repair shops should have this one. The R belt is a real thin and different material.
Posted on Mar 11, 2008
SOURCE: Need the manual for this vacuum cleaner
Try this link also
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action
Posted on Jun 14, 2008
galati2k
  • 281 Answers
SOURCE: Eureka boss vacuum, model 4331
if the switch is still connected the take one wire off at a time and put it on the new switch if you do it that way you can't make a mistake.try and get a wirng diagram from eureka or take it in and let a proffesional do it
Posted on Apr 10, 2009
How to replace the belt on a 4703 Electrolux vacuum
Instructions for changing the belt are found on page 20 of the manual (4700 series). A downloadable, printable manual is found at the below site.
http://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
Mar 09, 2011 | Electrolux Eureka Boss SmartVac Vacuum...
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How do i change the belt on the eureka boss capture vacuum cleaner
Here is a link to the belts you need and a manual you can view which has instructions:
Eureka Boss Capture Belt
Owner's Guide (3.06 MB download)
Dec 04, 2009 | Vacuums
It vaccum but it is really loud i dont know if there is something stuck in it or what is causing the problem.
It could be due to a stretched or worn drive belt. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 22, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Need to replace vacuum belt
how do i change belt on morphy richards ultralight cyclone cleaner?
Jan 04, 2009 | Vacuums
I have a eruka The boss vacuum that won't pick up anything
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=828446
Generic problem for all Vacuums
I have a Eureka The
Posted by jcross12 on Jul 24, 2008
I have a eureka the boss vacuum that won't pick up anything
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds t me like you may have a few problems, 1st the belt could be broken or stretched and is need of replacement. The belt should be changed every 4 to 6 months for the best cleaning. 2nd your vacuum cleaner could be clogged and stopping anything from going into the vacuum bag. 3rd it also could be your brushroll – the brushes end up getting soft and short and between the brushroll and the combination of the belt not working as well may cause it not to pup. Check your owner’s manual to see the trouble shooting section for unclogging your vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 24, 2008 | Vacuums
Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the
Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Go Ahead. Use Us.
Jun 07, 2008 | Eureka 431A Optima Bagless Upright Vacuum
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566792
posted by Deb in Iowa on May 03, 2008
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the instructions still available? Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I believe so, but you would have to contact the Hoover Factory and they would have to send out either the owner’s manual or a copy of the owner’s manual from the fische. I remember this vacuum cleaner well. In order to change the belt you need to remove the 4 screws in the bottom of the power nozzle and then the top cover will lift off from the back to the front and then you can get in to change the belt. Always use the Factory Genuine belts instead of the replacement belts, they last longer and the average belt change for a flat belt is every 4 to 6 months as a rule for the best cleaning. In order to change the belt, lift up the pulley side of the brushroll and slide off the old belt and then slide on the new belt and re-install the brushroll, then use a belt puller or screwdriver with a hook on the end and to pull or stretch the belt onto the motor pulley, once you have it on the vacuum track the belt in a straight line and then reinstall the top cover and screws in reverse. If you have questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 03, 2008 | Vacuums
Vacuums Logo
140 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
