Question about Sony Playstation 3 (PS3) Console
My ps3 wont read my usb flash drive it is formatted ncorrectly and everything someone pleeeeeeeeeeeze! help me!!!!!!!!!!!!!!!!!!!!!!
kriskogarcia
  • 98 Answers
SOURCE: PS3 Hard drive/Disc not reading
you can use the internet browser on the ps3 and find the pics in like photobucket or tiny pic and just save it from the web to your ps3.
Posted on Oct 12, 2008
retrohack
  • 27 Answers
SOURCE: My PS3 wont read disks
This is a laser problem. Blu-ray drives use a laser with a magnifying lens, and any dust on them at all will cause problems. These lasers are also known to fail and cost around $50 for a new one on ebay. You can also do a fan test to blow out your system. this works much better than using an air compressor. To do this, turn off the power switch on the back of your console, hold your finger on the eject button, then flip the power switch on the back of the system to the "on" position. When the fan comes on release the eject button. The fan should then go into overdrive and run hard for about 20-30 seconds. Keep in mind, if your system is pretty dirty this is going to blow dust all over everything around it,
so do it away from other electronics! Good luck...
Retrohack
Posted on Jan 20, 2009
RescueTechLA
  • 2653 Answers
SOURCE: USB WONT READ
It will only read the usb drive if it's formated with FAT32 or FAT16.
Have you tried reformatting the drive yet?
Posted on Mar 03, 2009
SOURCE: ps3 wont read disks
If YOUR WARRANTY IS UP. taking the ps3 apart is easy as long as you have the rght screw drivers. getting the plate off is the hardest part. there is a hex screw under the warranty sticker. after removing the screw, simply slide the plate down and it will pull off. then there are about 8 philips head screws on the casing itself. after removing these screws the top is hinged on the front side of the system... lift the back untin it is at a 90 degree angle and and remove the flat wire that goes to the SDcard slots by lifting the black flapwith your fingernail, then the top is removed. at this point the disk drive is no longe fastened by any screws of clips. pull the plug from the left side toward the front out to diconnect that set of wires. then there is a big flat silver strip connected to the bottom of the drive. once again lift the black flap to release this strip.now you are ready to open the drive itself. there are 2 silver screws on the bottom rear of te drive and 3 black ones at the front. you will need a very small philips head screwdriver for these. then the gray casing will come off. thelense is not exposed yet. there are still 5 or 6 tiny black screws on the top of the drive that will remove the black plastic case THERE ARE 2 TINY WIRES COVERED BY TAPE BE VERY CAREFUL NOT TO PULL ON THESE WHEN TAKING THE BLACK COVER OFF
. now the lenseis exposed. simply clean it with rubbing alcohol and q-tips and reassemble the machine. BE SURE NOT TO GET ANY OF THE WIRES PINCHED WHEN SETTING THE DRIVE BACK IN PLACE AND DONT FORGET THE LITTLE METAL GROUND ON THE RIGHT REAR OF THE DISK DRIVE. ANY ?S E-MAIL ME AT hartsedustin@yahoo.com
Posted on Apr 03, 2009
  • 11 Answers
SOURCE: ps3 wont read the controller, controller simply flashes
u unmatnictese it take it and get it fix
Posted on Aug 24, 2009
How do you unlock a verbatim 4 g pinstripe usb drive
right click on the drive and click format or re-format, this should erase everything on it and unlock it, but does not always work!
Dec 29, 2010 | Verbatim ® Store `n` Go USB Flash Drive,...
Wont start up
Does the light on the drive turn on? If not, try another USB slot.
I am assuming that you have a recent version of Windows. It should automatically load the drivers for the drive. If it does not, try the drive on someones machine. Does it work there?
If it does not work on someones machine, you likely have a bad drive. However, it could be that it needs to be formatted. [Write back if you need to manually format the drive].
It could be that it is just bad. However, that is fairly unusual.
Hope this gets you going.
May 24, 2010 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
My PS3 wont recognise 3.15 update from usb, formated usb to fat32 nothing works. Trying to swap the drive did the recomended instruction change and the system wont restart the new drive,went through all...
tilz1
If your PS3 will not see the update most likely you did not save the file to the right place.
The link below is the the main instructions to properly do the install of the firmware update. However when you save the you will wanted to save the update in a folder named "PS3” on the root directory of the USB drive. Then in that folder make a folder called “UPDATE”. After you have done this then you will want to save the update in the “UPDATE” folder. Doing this should allow your PS3 to see the update.
Let me know if you have any more problems or questions
Issken
http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
My mosearbaer pen drive cant be formatted and we also cant delete any files in the pendrive???
virus in your pendrive.
so format your pendrive dos command
start than run than type cmd than enter
ok and command type is
format (your pendrive colon) enter
i sure your pendrive format.
Feb 26, 2010 | Electronics - Others
How to recover flashdrive transcened 4gb v30, it can detect but i can't open?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Oct 11, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Cant use the USB! Says Close! nthing happens!
check the owners manual for the stereo and see what file system format you need to use on the flash drive i know i had the same problem when i changed radios worked on my old one but plugged into the new stereo wouldnt load had to unload the music and reformat the flash drive and then reload the music onto it that took care of the problem. where you have tried two different usb drives would say not likely you have bad drives
May 19, 2009 | Power Acoustik PTID-4003TV Car Video...
When i turn on my ps3 it does nothing else but go to the backroud
More than likely your hard drive was corrupted. The easiest way to fix it is to format the hard drive. There are LOTs of different ways to do this but the easiest way is to just hook the hard drive to a computer via a usb cable and then formating it through disc manager.
Here's a quick guide:
http://support.microsoft.com/kb/309000
It doesn't matter what file system your choose, just format it, and then pop it back into the PS3. It will recognise the hard drive as a new drive and then will reformat it again so that the PS3 can read it.
That's it! Problem solved.
The drives are SATA so if you don't have a usb cable you could always throw the drive into a laptop as long as it takes a SATA drive and use an XP or Vista CD and follow the same generall game plan: format the drive
OR you could swap the drive into someone else's PS3, it will do the same exact thing. It will recognize it as a new drive and will format it, then just pop it back into your old PS3 and boom. SUCCESS!!!
That's probably the easiest way now that I think about it.
Feb 19, 2009 | Sony Playstation 3 (PS3) Console
Ps3 blank screen
More than likely your hard drivewas corrupted. The easiest way to fix it is to format the hard drive.There are LOTs of different ways to do this but the easiest way is tojust hook the hard drive to a computer via a usb cable and then formating it through disc manager.
It doesn't matter what file systemyour choose, just format it, and then pop it back into the PS3. It willrecognise the hard drive as a new drive and then will reformat it againso that the PS3 can read it.
ORyou could swap the drive into someone else's PS3, it will do the sameexact thing. It will recognize it as a new drive and will format it,then just pop it back into your old PS3 and boom. SUCCESS!!!
Wont come on
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
USB WONT READ
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,174 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
