Question about IOGear GPSU21 Print Server
The segement of the print server you select is different from your computer" on Vista,
    President:
  • 2,923 Answers
Meaning that the IP Address of the print server is different from the computer's IP Address.
If you're computer has a static IP Address, you need to assign a static IP Address for your Print Server. To assign a static IP for the print server, you need to open the PSAdmin utility on your computer, locate the TCP/IP and click the plus (+) sign. Double-click the IP Address and you may change it from there.
Make sure that the IP Address of your computer, router and print server are in the same IP range. And make sure that you could ping the IP of the print server.
Then configure the printer port settings and you should be able to print.
Have a great day!
Posted on Jul 03, 2009
2 Suggested Answers
SOURCE: Does IOGEAR GPSU21 work with Vista?
I had a similar problem.
I had original printer install disk to help me with the problem
I went to PSAdmin and changed the DCHP Setting to allow my router to give it a new ip address.
I then added the printer using vista's add printer wizard: I used the add network printer and used the new ip address the PSAdmin gave me: I installed driver off disk, but then chose the one vista had already. I also used the "Print server 1 usb" device when asked which device I had installed.
Mutant
Posted on Aug 20, 2008
The segment of the print server you select is different from your computer
TROUBLE SHOOT GO TO DEVICES AND PRINTER THEN YOU WILL SEE PRINTER WITH YELLOW MARK ON IT RIGHT CLICK IT THEN ITS GOING TO ASK YOU TO TROUBLE SHOOT IT THEN IT WILL ASK YOU TO FIX IT.
Feb 07, 2011 | Zonet ZPS2102 Print Server
Tip
Configuring NETGEAR print server PS121 printer port settings manually.
If you can not run the installation software for the print server PS121 on the computer then you can try the below steps to manually configure the printer port settings:
Step 1:-
1. Visit the link below to make sure that the printer is in compatibility list:
http://kbserver.NETGEAR.com/kb_web_files/n101216.asp
2. Make sure that the printer is working in direct connection with the computer.
Step 2:-
1. Now connect the printer to the USB port of the printserver and then the Ethernet cable from the router to the Printserver Ethernet port.
2. Press the DIAGNOSTIC tool button on the printserver for 10 sec (All the lights will blink amber), you will receive a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router. If there is no ip address then powercycle the router, printserver and the printer. Press the diagnostic tool button again.
Configure printer port settings on XP computer:
1. Go to control panel then go to printer and faxes.
2. Right click on the printer icon go to properties.
3. Click on the ports tab on the top.
4. Click on add port.
5. Select standard TCP/IP port and click on new port.
6. Press next.
7. Enter the IP address of the print server it will show you the port (IP_ip address).
8. Press next.
9. Select the second option custom and click on settings button.
10. Select the protocol as LPR; enter the queue name as q1.
11. Select LPR byte counting enable.
12. Click on ok and press next then click on finish.
Configure printer port settings on VISTA computer:
1. Please confirm you are able to print by connecting the printer to the Vista computer directly.
2. Click Start - select Control Panel then switch it to Classic View from left side.
3. Double click on Printers & Click on 'Add a Printer'.
4. Select 'Add a local printer' & Click next.
5. Select 'Create a new port'.
6. Select 'Standard TCP/IP Port' as 'Type of port' then click 'Next'
7. Enter the IP Address of the Print Server in the 'Hostname or IP address' field.
8. Uncheck 'Query the printer and automatically select the driver to use' & Cilck next.
9. Select 'Custom' then Click on 'Settings' on the next dialogue box.
10. On the next dialogue box, select 'LPR' as the 'Protocol'.
11. Under the LPR Settings put in any name for the 'Queue Name'.
12. Check 'LPR Byte Counting Enabled' then click on OK and next.
13. Select the Manufacturer and the Model Number of the printer. If it is not available then click on 'Have Disk'. Click 'Next'.
14. Check 'Set as the default printer' and click next.
15. Try to print test page, it'll print.
These steps will help manually configure the printer port settings on the computer.
on Feb 10, 2010 | NetGear PS121 Print Server
Have installed a netgear ps121v2 server. Will work with the ethernet cable connected server to router and usb server to printer but will not work without the ethernet cable. System: Vista Home Premium ...
following steps can fix your Issue
regards,
prakash
Mar 14, 2010 | NetGear DG834G Router
Print server Iogear GPSU21 + HP Deskjet F4180 do not print!
The print server is Vista compatible. However, the Deskjet F4180 is not listed as a supported printer.Look at this list: http://iogear.com/files/pdf/GPSU21_Printer_Compatiblity_List_4-20-09.pdf . This print server is not the right one for your printer. You can either try a different print server, a supported printer or directly connect the printer to a computer and make that computer a print server for the rest of your network. The last option will take a bit more work. In Windows, the directly connected computer will need to allow sharing for the printer and the firewall software will need to trust the other machines in the network connect to it. The other computers will only be able to print and not use the other multi-function features. You may need to get additional software drivers to make this work (particularly if one computer uses a 64-bit OS and another has a 32-bit OS).
I hope this helps.
Jan 26, 2010 | IOGear GPSU21 Print Server
Print server was turned on today and doesn't recognize printer. It has worked witout a problem for over a year when we switched to a newer print server program
HI, Follow the steps below to reconfigure the print server:
1. Now connect the printer to the USB port of the printserver and then the ethernet cable from the router to the Printserver ethernet port.
2. Press the diagonistic tool button on the printserver for 10 sec (All the lights will blink amber), you will recieve a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router,If no ip address, powercycle the router, printserver and the printer. Press the diagonistic tool button again.
Step 2:- (For XP)
6. Press next.
8. Press next.
Step 3:- (For Vista Computer):
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 23, 2009 | NetGear PS121 Print Server
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Unable to install DP G 301 For laser jet 5 printer
0.Follow the manual instructions to configure the Printer Server (tpc/ip), connection toyour local wireless LAN, etc. then, specific for Vista: 1.Vista Start Button 2.Control Panel 3.Printer 4.Add New Printer 5.Select Local Printer 6.Click on "Create new Local Port" and from the menu "Standard TCP/IP Port" 7.Click on "Next" button 8.Menu "Type" select TCP/IP and write the IP address of your Printer Server. UNSELECT "detect printer to..." then press "Next" button 9.If everithing is fine, it must find your printer server. 10.Select your driver ... that's it .... unfortunately I found some problems printing documents: it works till half page then the printer stop and I must cancel manually from the printer the job in order to reset the printer itself.... looking for solutions
Mar 16, 2009 | D-Link Computers & Internet
IoGEAR printserver GPSU21 with VISTA
Yes, the GPSU21 is tested to work with Vista 32 and 64-bit Operating System. The things you need to do is listed below:
1. There's no need for you to install the CD that came with it, if the MFP Utility is already installed in another computer.
2. Get the IP Address of the GPSU21 from the computer that has the MFP Utility installed.
- Open the MFP Utility > locate TCP/IP at the lower portion of this window and click the plus (+) sign. > get the IP Address.
3. After getting the IP Address of it, go to your Windows Vista computer and ping the IP Address (just to make sure that Vista is seeing the Print Server).
- To ping, follow the steps below:
- Click the start menu and open the MS DOS Command Promt.
- On the black screen, type this "ping (type the IP Address of the print server): just like this
- C:WINDOWS\Desktop\Scott>ping 192.168.x.x and then hit enter.
4. Once you get ping statistics 4 packet sent; 0% loss. Then the Print Serve is communicating with Vista.
5. On you Windows Vista computer, make sure that the printer is working when directly connected to it. Because there could be a possibility that the printer driver is not properly installed that's why the server is not working.
6. On Vista, go to the Control Panel > Printers > Locate the printer icon (the one that is set as you default printer)
7. Right-click on the printer icon and then select properties > go to Ports tab.
8. Click on Add port button > select Standard TCP/IP > click on "New Port" (beside Cancel)
9. Hit next > type the IP Address of the print server. > Next
10. Click on Custom > Settings button
11. For Protocol: select LPR
12. For the Queue Name: type L1 > Click on OK > Finish.
13. Then under the printer properties, you will see the Standard TCP/IP is selected
14. Hit Apply so that the printer name would appear right next to that port > OK
15. Try printing a test page.
NOTE: After following the steps, you should be able to print using your Vista computer. I configured this print server with Vista several times and it does work with Vista.
Feb 19, 2009 | IOGear GPSU21 Print Server
Sharp 1642CS shared printer
You can go into your print driver and change the Driver. I dont think there is a difference between Home or Prem drivers. There is how ever a difference between 32 bit and 64 bit Vista?
When you set up the printer and share it from a PC, The printer attached to that PC can Control the Configurartion of the printer. PC's can either pull the driver from the sharing PC or you can select your own.
I would first check that the correct drivers are installed, (64bit or 32bit)
I would check the computer that is trying to print. replace the driver with the correct one.
You can open the print server -open the printers and fax folder, right click in a white area in that folder, a menu should pop up. Select Print Server from there you will see tabs, try to replace the driver from there.
Or Open the Printer Properties and there you will see Driver-Update in there.
This is a link to an explanation
Thou it was made for XP but the basic Infomation is the same.
-->Print a test page from The Printer Properties), if it works the Computer is fine, if you try to print from a program and it prints with errors. it is in the program..
http://www.fixya.com/support/r1173318-print_driver_location_pc_print_test_page
Nov 05, 2008 | Sharp AL-1642CS Copier
before running the PS Wizard in Vista, right-click on the icon for PS Wizard and select "run as administrator". This will clear the bind errors and wrong segment errors many times - this only applies to vista.
May 09, 2008 | IOGear GPSU21 Print Server
IOGear GPSU21 Print Server Logo
543 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
