Home | E-Machines | eMachines Desktop PC | EMachine T3958 Won't sta...
E-Machines eMachines Desktop PC
Problem for E-Machines eMachines Desktop PC
EMachine T3958 Won't start - Please help
By maidie2 on Jul 03, 2009
When I push the ON button on this computer, nothing happens. I notice that there is a green led light that is ON on the motherboard. Because I am an idiot, i assumed it was the hard drive and bought and installed that. Still nothing. No fan movement. No clicks. There is an extremely light, barely audible humming sound. You have to lean in to hear it.
My questions are - how do you know if this is the power supply?
If it's the power supply, then why would the green led be on on the motherboard?
Should I be looking at replacing the power supply AND the motherboard?
If so, where do i find a motherboard for this computer?
Any help would be appreciated. thanks.
Sponsored Links
Solution #1
posted on Jul 03, 2009
Not Rated)
DavisMcCarn
Rank: Guide
Rating: 88%, 4 votes
The green LED indicates that the standby voltage is present which is what provides the power so the front button can tell the unit to turn on fully.
At that point, there are 3 possibilities; the power supply has a fault and won't turn on, the systemboard has a fault and prevents the supply from turning on, and/or a connected device is causing a short.
Normal troubleshooting would consist of:
1) Trying another power supply (just set the system on its side and you only need to plug in the two connectors to the systemboard after unplugging all of the suspect supply's wires) If it then works (yeah!), hook the power back to the drives, see it boot, turn it off, then replace the supply inside the chassis.
2) Using the test supply hooked up to the systemboard, remove any add-on cards (modem, video, any USB devices, etc) and unplug the IDE (hard drive cables) from the systemboard. If it then works, put things back, one at a time, to find out which is fried.
3) Reseat the memory and CPU chip and try one last time.
If it is still no go, the systemboard is bad.
If you get to that point, this guy will need new video drivers; but, is a newer board which will let you upgrade further in the future: http://cgi.ebay.com/eMachines-Seabreeze-Motherboard-D845GVSR-103292-102240_W0QQitemZ260328632136QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3c9ccbaf48&_trksid=p3286.m20.l1116
Was this helpful?
Yes
No
Solution #2
Not Rated)
venexcsd
Rank: Guru
Rating: 88%, 390 votes
You need a voltmeter to check the supplies
5vdc & 12vdc are the two easiest becasue they are are the ones which are on the connector which supplies the Hard Drive you have just replaced
Red is 12v Positive Yellow is 5v Positive and the black wire is Neutral
You can remove the main board connector from the power supply to the MB but you need a copy of the Motherboard installation manual to tell you what supplies are on that connector
Was this helpful?
Yes
No
Popular Solutions for E-Machines eMachines Desktop
Questions and Unsolved Problems for E-Machines eMachines Desktop
Do you recommend E-Machines eMachines Desktop PC?
Answer
Answer
game froze points didnt register golden raider game
Answer
eMachines T3418 mi no arranca solo suena el ventilador ya prove con elotro Power Supply y sigue... (More)
Answer
Yea sorry, forgot that tid-bit of info. It,s the W3118 eMachine / Gateway FIC K8MC51G
Answer
Was just curious if there was a way to set my refresh to an auto position, to make it refresh... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For E-Machines eMachines Desktop...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 1417
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
