Question about Hobart AM14C-155 Dishwasher
No heat on rinse cycle HOBART AM14C Dishwasher
CON 3 keeps banging away(on off on off)..no heat on rinse cycle sometimes, but when we do it drops off after first load...I am thinking element in the booster tank and or thermostat in booster tank. My inlet water at regulator is 120F..pressure on fill and rinse is at about 19. Changed board in control panel and float/thermometer in machine already as well. As per 2 Hobart service guys, but now thinking its booster tank problems. Unit seems to heat after long time between loads which makes me wonder how many elements in booster, maybe one not good and causing the contactor to open close repeatedly. Or bad thermostat that causes unit to not heat because it thinks its bad. Any help would be appreciated.
  • tablesaw4 Jul 03, 2009
    I should also add that the rinse temp screw is fully adjusted (counterclockwise) and the wash time has been extended to 60 seconds and still nothing. Adjusted rinse temp screw since that was the board that was changed.
    rinse temp screw is fully adjusted and wash time has been extended as well
  • 110 Answers
ITS MOST LIKELY A HATCO BSTR . IF THE TANK CAN BE SEEN ITS NOT HATCO.FIRST JUMP OUT T'STAT ON BSTR SO ITS ALWAYS CALLING FOR HEAT CK. ALL ELEMENTS FOR AMPERAGE. BE QUICK SO BSTR. DOES NOT OVERHEAT ON YOU.IS CONTACTOR STILL CHATTERING, IF NOT REPLACE OPER. T'STAT FOR BSTR
Posted on Jan 11, 2010
    Scholar:
  • 109 Answers
3 Con, is the booster heat contactor. If it is chattering, the fault will be in the booster. There are a few different boosters in the AM14. can you post the ML number from the data plate, or describe if the booster is a square Hatco HCM-10, or a round stainless booster with a 13 kw multi wired element.. All boosters use a low water cut off circuit, a high limit thermostat and a control thermostat. The old Hatcobooster uses mechanicqal components, where the new rount tank uses probes and a control board. The board has 3 leds. red is calling for heat, yellow is open thermistor, and green is shorted thermistor.
AM14's had a variety of different control circuit voltages, ranging from 240/208/120 and 24 volt AC. Check the transformer secondary for correct output to controls, trace through circuit until voltage pulses. If new style, it could be just scaled up probes not reading water. Drain the tank with the power off before removing probes.
Posted on Aug 13, 2009
Hobart undercounter high temp dishwasher not heating water
am14 is not an under counter. Please specify what you have and is the issue is with wash or rinse heat.
Dec 31, 2013 | Hobart AM14C-155 Dishwasher
Rinse temperature too low
your right dont guess the board is bad!
Aug 08, 2012 | Hobart AM14C-155 Dishwasher
I have AM14C Hobart dishwashing machine and when the rinse turns on we only get about 5 PSI, how do I adjust the pressure or what do I need to look at?
the pressure regulator turn screw clockwise to turn up pressurre.But the line strainer could be plugged do you have bad water.Is the gauge correct.you can get a gauge at home depot for cheap.0 to 60 psi should be ok.usually made by watts.you dont have to use a hobart gauge.
Apr 22, 2011 | Hobart 42 in. AM14C-154 Free-standing...
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
Can I change the 3 phase to a single phase?
Not practical. You would have to change the pump motor to single phase, you'd have to chage the heating element most likely depending on what size is in it now. Also does it require an auxiliary water heater? it's probably 3 phase also. Changing phases is not like changing voltages.
Jul 24, 2010 | Hobart AM14C-155 Dishwasher
Hobart dishwasher am14 displays 255 in temp window heater wont fire
The wash thermistor is shorted. The float and probe assembly in the wash tank should be replaced.
Jun 13, 2010 | Hobart AM14C-155 Dishwasher
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Need to know AM 14 rinse cycle water useage
12 second sof rinse used about 0.8 gallons at that presurre
Feb 17, 2009 | Hobart AM14C-155 Dishwasher
Hobart am14c water keeps spraying even with power off
The internal parts of the solenoid valve are bad.if your standing in front of the machine look to the right in the back you will see the water line going to the valve.turn the water off,remove the black coil and set aside,then unscrew the valve with a pair of channelocks or pipe wrench.clean all the parts up and reinstall.if this doesnt do the trick you need to replace those parts.let me know.
Mar 28, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart AM14C-155 Dishwasher Logo
402 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
