Question about Mtd Garden
Runs for about 5 secononds then runs out of gas
  • Dwain Pippen May 11, 2010
    Does this have the rectangular fuel tank on the side with the carb and air cleaner on top of it?
    Problem Solver:
  • 5 Answers
The float valve may be stuck, but most probable cause is the nut that holds the float bowl probably has a plugged up hole, remove the nut and about half way up there is a little hole you can unstop with a bread tie which the plastic is removed, unplug this hole and reassemble the float bowl, that may fix this problem
Posted on Jul 29, 2009
Why does it run for 10 mins, then stops?
Loosen Gas cap and see if that helps. Many times the Gas tank Vent gets clogged. When engine runs, it creates a suction and starves the engine of gas.
OR
If the engine was stored with gas in it, sometimes the Rubber seat in the carburetor deforms and wont let the gas flow into the Carb Bowl at a fast enough rate to keep up with the running engine. The bowl empties (after 9 minutes) and the engine quits. Takes a while for the bowl to refill (5 minutes).
Jan 16, 2016 | Toro Snow Blowers. Power Clear 621 QZR 21...
78 Harley with points runs for 5 miles and shuts down
After the restart, how long will it run for?
If only another 5 miles, it COULD be the gas tank venting isn't working, and you're vapor locking.
Next time it dies, remove gas cap and see if it restarts without the few hours time span.
Jan 13, 2014 | 1987 Yamaha YX 600 Radian
Control panel is blank and the gas company checked the pressure, it is at 5. The heater is not activated.
first of all, if the inlet gas pressure was only 5 inches water column the heater will under fire once it runs. that pressure will have a slight drop once the heater is running. So, the gas company should have known that and realized the gas line may have been undersized. Secondly, if the control panel is blank you probably have a problem with the transformer inside the heater. The secondary side will send out 24 volts, the control panel also runs on 24 volts.
Sep 18, 2013 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Dryer gas ignites Runs for up to 5 minutes flame goes out
check the igniter to make sure it is glowing white and not orange. if it's orange replace it. you may also need the gas coils replaced.
Oct 16, 2009 | Hotpoint Dryers
Weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
Jun 28, 2009 | Poulan Pe550 Gas Edger
Snowblower runs then quits
check to see if gas cap vent is clear . its the little pin hole at the top of cap . if not clear it will cause a vacuum and stop the flow of gas ... good luck
Dec 19, 2008 | Mastercraft Garden
Garden Logo
87 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
