Question about Craftsman Garden
Fuel problem gas geting into my oil,gas and oil pumping into air cleaner through vent tube that connects from air cleaner to block
  • 376 Answers
The float needle and seat is leaking. When the bowl is full, the needle and seat is not shutting off the flow of gas. It flow up into the carb, down the intake, past the intake valve and piston rings into the crankcase. The needle and pressed-in brass seat need to be replaced.
Posted on Jul 03, 2009
  • t-makaveli Sep 04, 2011
    I had the same problem. But I can almost guarantee the aforementioned solution is not going to fix what's happening in your case. Here's what's most likely going on. The tube in the air cleaner housing, where that oil/gas mixture is shooting out of, actually connects to the "crankcase breather" (little rectangle box that is bolted into your block). What is most likely the cause of your problem is a blown head gasket between the cylinder, and the push rod valley. This causes oil from that valley to be sucked into the cylinder on the intake stroke, (thus mixing with fuel), and then get pushed back out into that valley on the compression stroke. This explains thee oil/ fuel cross-contamination. The reason it "spurts" out of this "crankcase breather" tube, is because the blown head-gasket is allowing all the pressure from the pistons compression stroke to enter into the crankcase, via the push rod valley, and force this oil and gas mixture out of the crankcase through the past of least resistance. Which in this case, happens to be through the crankcase breather tube. Hope this helps anyone with the same problem I had.
  • Vicki Kinchen Jun 10, 2012
    If I unplug the connector at the bottom (bowl) of carburetor will that keep gas from continuing to flow into carb. when not running? At least until I can get a shut off for it.
150cc roketa 4 wheeler 4 stroke. the fuel pump has 4 outlets on it Fuel in, fuel out, vacuum, and vent. What does the vent outlet connect to?
probably nothing as it is a vent tube to allow equalization of pressure on the fuel in the carby
at best it will connect to the air cleaner area at the air filter
Apr 17, 2017 | Cars & Trucks
Yamaha roadstar 1600
One line that comes from the top LH side of carb (looking at carb w/o air cleaner) is a carb vent aprox 1/4 " hose. It connects only to the carb & hangs in a wire bracket as a vent tube. The 1/2 " vent line that goes from the valve cover on the rear cylinder goes to the spigot on the air cleaner case & vents the crankcase gases back into the intake of the carb to be burnt. Those are the only 2 lines other than the fuel line that comes from the metal pipe that crosses over to the fuel pump on the other side of bike. That fuel line connects to the carb metal fuel spigot on the side of the carb. That's fuel into carb.
Mar 26, 2014 | 2002 Yamaha Road Star
2010 Vespa, tried starting and runs while just idling. However, when you try to give a little gas it quickly dies. I did Tue best I could checking the air filter, fuel filter, spark plug, etc. Stuff I...
Hi, Divecop3 these tubes and hoses are for venting and must remain clear of obstruction and connection at one end otherwise the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa My Et4 dies as soon as give it gas
Scooter dies when give it gas
May 23, 2017 | Vespa Motorcycles
Bandit 1200 oil in crankcase
No i would not expect it to, if anything blocking the vent hose to the gas tank would cause a vacuum and stoping fuel from flowing as easy , most likely a faulty fuel pump diaphram or incorrect float height.
Feb 22, 2012 | 2001 Suzuki GSF 1200 Bandit S
I have a 2006 F250 which I have lots of aggravating problems with trying to fuel up. No matter which gas stations or method of inserting the nozzle into the fill tube I use, I am frustrated by the time it...
where the filler neck goes to tank didnt it have seperate tube which is vent or with filler neck hose off at tank look inside tube for another hose it is vent hose take fuel cap off and blow air from tank end towards the filler cap area we have had two ford vehicles lately in our shop when we blow shop air backwards thru hose several little round pieces of foil off of fuel injector cleaner bottles somehow they had become lodged in vent line and one customer had vehicle towed from gas station because they were on empty and would accept no gas you may want to check this doesn,t have to be cleaner bottle tops could be any sort of debris but ours came flying out of fuel cap when when blew air thru you could pump gas with handle all the way down she was happy
Mar 24, 2010 | 2006 Ford F-250 Super Duty
Slow filling of the gas tank
the block you encounter in filler neck is an anti-siphon device most problems go away but if persistent can have a problem with evap system
Problem filling my gas tank Automotive Fuel Tank Problems Car Repair Information From MasterTechMark Why can fill my gas tank in one go
Apr 28, 2017 | Hyundai Accent Cars & Trucks
CRANKS OVER WONT START HAS SPARK,FUEL TO PRESSURE TESTING FITTING? 454 7.4 FUEL PUMP OK NEW FUEL FILTER WHAT DO I LOOK FOR NEXT.
It's not flooded is it? Try holding the gas pedal to the floor while trying to start it. If that don't work try taking an oil can and put some gasoline in it. Now try to squirt some gas into the intake somehow, there should be a hose that goes from the air cleaner tube the valve cover. Pull that hose off and squit some gas into the air cleaner tube. Will it fire like that? Are you getting a check engine light? It's possible the cam position sensor is bad you will still have spark but, not at the right time. Good luck.
Jan 04, 2010 | 1996 GMC Suburban
1975 yamaha DT 175 it floods when the gas tank
I had the same problem - actually more than one problem:
1) Floats in the carburetor bowl (at the bottom of the carb) are getting stuck. Remove the carb; carefully disassemble the bowl & float assembly (pay attention to gasket orientation and don't lose the needle valve that the float-tab presses on!); use a carb cleaner from AutoZone or similar, and a toothbrush to clean all the parts. If carb is not too dirty, leave the jets and mixture-adjust screws alone (otherwise will have to re-adjust later).
2) Overflow tube is plugged (hence fuel in the cylinder instead of on the ground). Clean both ends of the brass-looking tube from inside and outside the carb bowl. Make sure you can blow through it or it is still plugged. Toothbrush and carb cleaner should do the trick. Replace the short flexible tubing that connects to the overflow on the outside of the bowl - transparent polyurethane tubing is less than $1 per foot at your local ATV/motorcycle shop.
3) Air Vent tube is plugged. Same thing as the Overflow tube but mounted higher up in the carb (not in the bowl). Clean it the same way and replace the flex tubing with another short piece of polyurethane.
4) Make sure the float-tab and needle-valve move smoothly. Mine was catching and getting stuck so I carefully "polished" the face of the tab with 400-grit emery paper, and then made sure to clean the area from grit. Smooth as a hot knife through butter now.
5) Set the float level by CAREFULLY bending the tab that pushes on the needle valve. On my 1981 175MX, float height spec is 21mm when just making contact with the needle. Yours may be different though.
6) Reassemble the carb after making sure all dirt and debris are gone. Use a new bowl gasket or at least put a good gasket-sealer compound on the old gasket. Attach the short lengths of transparent polyurethane tubing to the Overflow and Air Vent. When installing the carb, the Air Vent tube should just be 2" long and point out to the side; the Overflow tube should route through the frame near the swing-arm and point down to the ground.
7) MAKE SURE the Oil Feed tube coming from the AutoLube oil pump is connected to the carb (brass-looking fitting toward the cylinder-end). I replaced mine with transparent polyurethane tubing (different size than the Air Vent and Overflow), so now I can see that oil is being presented to the carb!
8) If the carb was nasty-dirty, you may need a new air filter. Mine was disintegrating. I recommend also putting an in-line fuel filter between the petcock and the carb, again using short lengths of TRANSPARENT polyurethane tubing (so you can see that fuel is flowing). You may also need to adjust & prime the AutoLube oil pump.
I highly recommend getting a Clymer manual (check eBay) which shows all these procedures and gives you the right specs for float height, etc. based on your model / year.
Aug 11, 2009 | 1974 Yamaha DT 360
Garden Logo
352 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
