Imagistics Error Code C-0B77
Copier stopped working and will only give the home screen message of ''Malfunction detected.'' and gives the error code C-0B77. We do not have a maintenance agreement on this machine so we do not have a technical service representative to contact. Which leads to the next question: How do you find a maintenance provider for Imagistics copiers?
(We are a non-profit and had this machine donated to us.)
  • Ocetech21 May 11, 2010
    first of all i need the model number of the machine, you cant just list an error code. second, you can still have an oce technician service the machine but there will be an hourly rate. you can purchase a maintenance contract through Oce imagistics. if you have a 3rd party service contract work on the machine we will not service your machine in the future.
  • Office Equip... Master
  • 6,696 Answers
May want to check the stapling unit and hole punch. To reset open close front door. After openclosing finisher door
Posted on Jul 12, 2009
Imagistics all in one copier/fax/scanner im2520f. All is working except the scanner which is giving error code EA21F7.
Try restarting your printer to see if the scanner lense moves properly and not jammed next you need to download the latest driver and suite from manufacturer`s website which shall definatly solve your problem.
Sep 30, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn On the copier.
Keep pressed the Utility key and wait while Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 19, 2013 | OCE 3140 Copier
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Imagistics dl270 code c0070
A error code C0070 means that the toner bottle can not find home position. Did you just install a new toner bottle??? If so, carefully remove the toner bottle and close the front door and let the copier warm up... Once it is warmed up install the toner bottle again.... If it will not clear you have more of a problem with the toner hopper... Good Luck
Jun 08, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
I have a imagistics cm3120/cm2020,,It gives me a malfunction c-0400 message,,what can i do?
type in this code on Google! Does it start up proper? Goes through its ritual of checking its parts.
Jun 27, 2008 | Office Equipment & Supplies
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
Malfunction code C0200
A C0200 is a Charge Corona problem and it is a Minolta error code.
Jan 23, 2008 | Office Equipment & Supplies
264 people viewed this question
k24674
jasbo
jasbo
