Question about Gateway FPD1965 19" Flat Panel LCD Monitor
It turns off after 10 minutes working
It turns on and produces an image for only about 10 minutes, then turns off.
  • 32 Answers
When you say it turns off, is the power light going out too?
If the power light is still lit when the screen blanks, it may be a faulty backlight inverter.
After 10 minutes elapse and the screen goes out, if you power it back on, do you get another 10 min, or does it last a much shorter time period, or not at all?
Your best bet is probably simply to buy a new monitor, and sell yours as "broken" on eBay, I'm sure someone out there capable of fixing it would be willing to pay pennies on the dollar to subsidize your replacement screen.
Posted on Jul 03, 2009
MT 600101 oil-less compressor, pdf manual. I specifically would like to know the scfm ratings at 40 and 90 psi.
the air flow from a compressor is determined by the capacity of the pumping system
with a piston type compressor it is the bore by the stroke
in a diaphragm type is it is the diaphragm dia by the stroke
that is the maximum cubic feet of air a minute produced
pressure is the resistance to flow so regardless of the pressure or restriction it will only produce that set air flow at that rpms
do not confuse the flow with pressure as it works like this the greater the restriction the greater the pressure in reserve but the less flow in cubic ft per minute through the restriction
for example a compressor producing 10 cubic feet per minute does that with not restriction but with no pressure
at 25% restriction to air flow the pressure in the tank will now rise to say 25 psi and the flow from the restriction will drop to 8 cubic feet per minute
at 50% restriction the compressor is still putting out 10 cubic feet of air per minute but the tank pressure has risen to 50 psi and the flow from the restriction has dropped to 4 cubic ft per minute
go to the extreme end and the compressor is still producing 10 cubic ft of air per minute , the restriction now allows 100 psi in the tank but the low from the restriction has been reduced to 2 cubic ft per minute
the simple equation is pressure = flow X resistance
Jun 24, 2017 | Air Tools & Compressors
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
Converter only works properly after it has been left on for about 20 minutes
In my years as an Electronic Technician I have had two simular situtions happen to me. Both were in TV's but the results was the same, they had to 'warm up'. Then they played fine until they cooled off. I finally discovered that in the power supply I had a ceramic resistor that should have been about 2 ohm had changed to Mega ohm and was not letting power through fast enough to start quickly. Once it got the caps built up it worked fine. The other was also in the PS and it was a large cap that was just slow to take a charge. Don't know that either of these fit your situation but that is the only two times I have experienced a problem of that nature
Mar 12, 2014 | Sega POWER BASE CONVERTER
I am producing a 10 minutes video but after the video file is completed the video is only 3.5 minutes long although the production report stated it is 10 mins.
it must be because the software u r using has a time limitation due to license issue....
if u can give me full details i can solve ur issue...as i am an expert in producing/editing movies
Jul 08, 2010 | TechSmith Camtasia Studio for PC
What are the best settings to produce Hi Res images suitable for magazine publication
For the best image that a finepix S2000HD can produce use the Maximum resolution is 3648 × 2736
and check for 10 mega pixel settings.
This will give freedom to edit the pictures and do what ever you want to the pictures.
Apr 13, 2010 | Fuji FinePix S2000hd Digital Camera
Receiver buzzes after being turned on for about 5 to 10 minutes. Nothing attached.
The only thing I can tell you is that a semiconductor is after 5 to 10 minutes is probably getting hot and when it does it produces the noise. I would take the top off and see if you can pin point the noise, then replace whatever is doing it.
Feb 27, 2010 | Onkyo TX-SR606 Receiver
Fixes for a Polaroid TV thats not turning on
Hello:
37 inchs have a television of the problem is that it works like 10 minutes and turns off the image, has sound but no image, turn off and on again returns to normal work and 5 minutes the picture goes but still sound, can you help?
Oct 20, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Picture on my TV starts to flash after a few minutes of use
This problem is common in Samsung projection TVs. The DMD board is going bad.
Mar 21, 2008 | Samsung HL-R6167W 61" HDTV
I'm getting really confused with the resolution stuff
The C4000 is a 4 megapixel camera and can produce photos that should produce very nice 8 x 10 photos. 11 x 14 prints may be pushing it a bit. Your cameras should be set for 2048 x 1536 and the .jpg compression should be set to "Super High". Better yet, that camera can produce TIFF format. For photos you plan to print, use the TIFF format. The other half of this process is the printer. Most inkjet printers have a number of settings. Make sure that it is set for photo paper and be sure to use glossy photo paper. If you can print a 8 x 10 print in less than a minute, your printer is not set right. If it seems like it is taking forever, it is set right. .................... Using Photoshop Elements 2: Open your photo into Elements. Click Image, Resize, Image Size Remove the checkmark from "Resample Image" Change resolution to 300. Notice that the width height is about 5 x 7 inches. So if you print that photo at 300 dpi (dots per inch), you will get an outstanding 5 x 7 print. Most inkjet printers produce their very best outputs at 300 dpi. At 200 dpi, the image is still quite good. When you get below 150, you will start to see changes in quality. Now set the Resolution to 200 dpi and notice that the output size has changed to about 8 x 10 inches. Now check to see how it will look on paper. click OK. Click File, Print Preview You can verify that the photo fits on the paper and that the paper is correct (horizontal/vertical). Now print the photo. The next window that opens should let you get to your printer properties and you can verify that you have the printer set for it best settings and that paper is set to photo paper.
Sep 06, 2005 | Olympus Camedia C-4000 Zoom Digital Camera
Gateway FPD1965 19" Flat Panel LCD Monitor Logo
108 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
