Question about EliteGroup ECS A780GM-A Motherboard - AMD 780G, Socket AM2+, ATX, Audio, Video, HDMI, PCI Express 2.0, Gigabit
Ecs gf 8200a usb ports dont work, running vista 64
Ecs gf 8200a running vista 64 cannot get the usb ports for the front of the computer to work i tried the different ports on the motherboard, no luck, i contacted ultra thinking it was the case and they sent me a new usb/audio port plate for the case. when i hooked the new one up, it worked for like half a day, i've tried to find solutions at the ecs website but no luck yet. I would really appreciate any help, not being able to use my front usb ports really sucks.. game controllers, ipod, etc, have to get plugged in the back....
  • 380 Answers
Could be a bum board or specifically, bum usb controller on the board. Make sure you update your BIOS, and make sure the BIOS says the front USB is activated. You also want to make CERTAIN you have the USB drivers from the motherboard mfr site, because windows native drivers might not be as good as mfr drivers. Also, put a flash drive in the front USB and try to boot from it (youd prolly have to get some linux bootable OS thing to do that with, but im sure its out there somewhere), because if you can boot from a flash drive, it would mean the issue is in the windows OS, and not your bios or usb firmware. Finally, make sure there are no broken USB ports on the board itself, a messed up port on the board might corrupt the rest of them. If all that should fail, you could bypass the problem by dropping an external USB hub on the top of the machine and plugging it to the back. I know thats ugly and causes clutter, but it would solve the immediate issue: the lack of ports. Youd likely be better off with another board though because it seems that the front usb controller is simply not functioning correctly. If you do have to replace the board, get a board from the same mfr with similar features, so that windows vista will be able to start it, or you may have ro reload the OS.
Posted on Jul 03, 2009
Front panel USB connection
You have an ECS board and that is not enough info for us. We need to know the model number of it.
Nov 13, 2017 | ECS Computers & Internet
On a Fujitsu fi-6230 I keep getting an error occured communicating with scanning device. please ensure that the scanning device is connected properly and try again.. i have to keep uninstalling and...
This a USB scanner and it supports the following OS's: Microsoft® Windows® 2000 Professional / Microsoft® XP (32 bit/64 bit) / Microsoft® Windows Server™ 2003 (32 bit/64 bit) / Microsoft® Windows Vista™ (32 bit/64 bit). IF, the usb cable is connected in the front usb connectors go ahead and plug it in the back usb ports since sometimes the front usb ports are either to slow or not connected. Additional, after pluging the the scanner on the back usb ports restart your computer and then proceed reinstalling the drivers for it.
Mar 25, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
I connected the external floppy drive to a USB hub which in turn is connected directly to a USB port on my Dell desktop which runs Windows XP Home Edition 64 bit version and the drive just runs and will...
Yes, the external floppy drive must be connected directly to a USB port on the computer instead of to a USB hub.The PC can't see the drive thru the USB hub. Applies to both 32 and 64 bit.
Sep 07, 2009 | Computers & Internet
ECS GF 8200A does not support more than 3 gig ddr2 memory
Is the mainboard capable of supporting more than 3 GB?
If it is then maybe you have the wrong kind of memory, or the slot is bad.
Take all your memory out and just try with the new stick in one of the good slots. If it works then we know the memory is OK so then try it in the "bad" slot.
Sep 05, 2009 | Computers & Internet
An error occurs "usb device not found" when using flash drive or
you can connect your usb at back of cpu,,,,,may be it work.you should connect your usb on different ports
Mar 11, 2009 | EliteGroup ECS P4M800-M7(3.1) LGA775 ALL...
Sky caddie sync makes using more difficult
You must let the Windows Installation Wizard run and install the drivers. Then the computer will find and connect to the sky caddie.
Feb 11, 2009 | SkyGolf SkyCaddie Handheld GPS Unit
Additional USB ports not recognised
seems that none of the ports are working
Jan 19, 2009 | ASUS P5PE-VM Motherboard
Samsung ml-1740 printer - their driver not compatible with my Windows Vista
you must go to printer in control panel, then right click the desired printer icon, then click properties, then click on Port. then if using usb port, you must check each port untill you find the correct usb port that you are connected to (click apply each time). may take a couple tries untill you find the correct usb Port that the cable is connected to. worked on my HP desktop, finally
Sep 01, 2008 | Office Equipment & Supplies
EliteGroup PM800M2 motherboard
This motherboard dont have a software/driver for Vista ECS didn't create a software for vista that's the reason why the other components of the MOBO wont be working fine with vista like the video, and usb because of driver problem.. But it do have a driver for ethernet card and RAID for vista that's all they have created , this is the link for it so you can also check it http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=453&DetailName=Driver&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
Hope that helps...........
Sep 01, 2008 | EliteGroup PM800M2 Motherboard
EliteGroup ECS A780GM-A Motherboard - AMD 780G, Socket AM2+, ATX, Audio, Video, HDMI, PCI Express 2.0, Gigabit Logo
246 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
