Question about Nokia N93 Cellular Phone
The front of my n93 display lights every 3 mins even if theres no text or call..is it grounded or something?.. so it tends to make my battery drain
Why does battery light come on when in reverse?
low idle causes the alternator go below min voltage = batt light
main harness for the engine compartment is routed between the
firewall and exhaust header/egr tube. Bad location plus the harness is attached to the metal coolant by-pass tubes, a failing motor mount
could let the harness "ground". A '95' Taurus usually takes 2.5 to 3 years to eat a fresh battery. The elect system is draining the battery
even when its parked!. If the cables/terminals are sound and tight and a voltmeter test indicates 13.75 - 14 volts when checked at the batt terminals, with engine at idle and tranny in park. Have someone
apply the brakes and shift to reverse, take another voltmeter reading. There shouldn't be a significant drop in the two tests. If the engine rocks badly on the mnts and the second test has a voltage drop under 12 volts. Then a short to ground is very likely. Take it to a parts house that will test the battery and alternator for you.
but if the battery is over 2 yrs. old, then your going to replace it soon.
let me know if you would please.
ej
Apr 29, 2014 | 1995 Ford Taurus
My 2007 gmc yukon reverse light stays on after i even shut my vehicle off what causes that?
Alot of these new trucks keep the reverse lights on for safety so you can see, they can be turnned off using the console display, you will need to read the manual it will tell you how, there are a lot of feature that can be turnned on or off,
if you start the truck and the reverse lights stay on or if you turn it off and get out and lights stay on for more than 5 min then there is a problem, let me know if they stay on and drain the battery, otherwise it is just a feature, it can be shut down if you want, i also belive the front lights stay on also for a while unless they are shut down. good day.
Sep 30, 2012 | 2007 GMC Yukon Denali
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Why does my battery keep going dead I have relaced it 3 times a new alternator if the car sits for 2 days or more and is not started and ran the battery is completely dead
BATTERY DRAINS ARE TRICKY. TURN OFF ALL SWITCHES, CLOSE GLOVE BOX. MAKE SURE GLOVE BOX LIGHT IS OUT. OPEN THE HOOD. DISABLE THE UNDER HOOD LIGHT. CLOSE ALL THE DOORS. MAKE SURE ALL COURTESY LIGHTS ARE OUT. DISCONNECT NEG. BATTERY CABLE. USE 12 VOLT TEST LIGHT, CONNECT ONE END TO A METAL PIECE ON THE MOTOR FOR GROUND. FASTEN THE OTHER END TO THE NEGATIVE BATTERY POST. IF THE LIGHT IS ON, THAT MEANS THERE IS A BATTERY DRAIN. LIGHT NOT ON, NO DRAIN. IF THE LIGHT IS ON, FIND THE POWER BOX NEAR THE BATTERY. PULL OUT ONE FUSE, IF THE LIGHT STAYS ON PUT HE FUSE BACK, PULL OUT THE NEXT FUSE. IF THE LIGHT STAYS ON PUT THE FUSE BACK . REPEAT THIS UNTIL THE LIGHT GOES OUT, OR GETS VERY DIM. OUT IS BETTER. WHEN THE LIGHT GOES OUT, THAT IS THE CIRCUIT THAT IS DRAINING THE BATTERY. REFER TO OWNERS MANUAL TO IDENTIFY THE CIRCUIT. IF THE LIGHT NEVER GOES OUT, REMOVE THE WIRES FROM THE ALTERNATOR. IF THE LIGHT GOES OUT, ALTERNATOR NEEDS REPLACING.
Jan 15, 2011 | 2003 Ford Mustang
My battery keeps draining after 2-3 days, I've had the alternator checked, in which it is working properly. What could drain a battery after that short time span. the battery has been replaced twice
For starters, make sure that you don't leave any electrical components on. If that is not the issue then check the cars wiring. Have an electrician check it for you. My hunch is that there is some wiring somewhere that is not properly grounded and/or there is a short circuit somewhere. These two things will lead to battery drain especially since removing the key from the ignition does not turn all the electrical components off. (ex. the headlights, horn, tail lights, brake lights, interior light may be turned on even without the key.)
Dec 17, 2010 | 1996 Nissan Sentra
I have a brand new battery in the vehicle and it went dead in less than 2 weeks. Would the computer located in the fender well have anything to do with the battery being dead? I have had the alternator...
You need to check for something that is a constant drain on the battery.
Is the underhood light staying on?
Are the interior lights left on?
Is the glove box light staying on?
Has anything been added to the van recently like an alarm, radio, amplifier, etc?
Do you leave your GPS unit plugged in or cell phone charger plugged in?
I would start my search (since you have already had the alt output checked) looking for something that is draining the battery slowly.
Feb 23, 2010 | 1998 Chrysler Town & Country
Gep prizm wont start
It sounds like a bad ground or something. I'd check your battery terminals and wiring. Also, follow the ground wire from the battery to it's connections. These tend to cause a lot of problems like this.
Sep 14, 2008 | 1995 Geo Prizm
Incoming text
remove some of the stored messages from inbox , out box, ect.
Feb 10, 2008 | Nokia N93 Cellular Phone
Screen says battery is full, but wont turn on
I read somewhere that even with a functional lyra, when it displays "battery full", you should keep charging for another hour. This is said to extend battery life and give you an extra 2-3 hours of power. Either this is perfectly normal, or it indicates that the battery reading tends to be inaccurate. In any case, try leaving it charging even after it gives you the message. Another thing to consider is, how long has it been in the box? I'm not sure about lithiums, but most rechargeables I know live longer when used. Live it alone for too long and you shorten it's life. Could be good to get a second opinion on this battery thing though. If there's a warranty, don't let it waste. Good luck
Jun 20, 2006 | RCA Lyra RD2840 MP3 Player
Nokia N93 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
