Question about Janome 405 Mechanical Sewing Machine
Bobbin sucking in upper thread through foot plate, tangles in 10s
1. I'm not sure the bobbin is turning in the right direction. Should it move with or against the direction of pull?
2. I'm not sure the upper thread tension is right. I am using a thick cotton thread in both spools.
3. I have it set to 4/2, st length 3, diagonal 0. I am getting straight but not long stitches.
    Problem Solver:
  • 5 Answers
Try using a bigger needle when using thick cotton,cotton can get stuck in needle groove
Posted on Sep 06, 2009
What is happening when I sew and 3 threads come out of the bobbin? Or when it just freezes up and I can't get the needle to go up or down?
basically the problem comes from incorrect thread tensions
the main thread responsible is the needle thread as the tension is far too loose
tighten up that tension and it makes the needle on the up stroke pull the thread around the bobbin carrier and collects the bobbin thread and pulls it up to the material
with the needle thread too loose the needle thread is wrapped around the bobbin carrier again giving you the 3 threads ( 2 needle threads and 1 bobbin thread and the tangle jams the bobbin movement
Sep 29, 2016 | Sewing Machines
When I press on the pedal the machine just makes a 'vruuuuuu' sound, and when it sews it tangles around the bobbin! It also does not pick up the bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Damaged needle
8. Warped bobbin
9.First make sure the bobbin-winding spindle (located on top of your machine) has been pushed back to the left for sewing.
10.If it is not in the correct position, the needle will not go down and pick-up your bobbin thread.
11.Next make sure your needle is inserted correctly, with the flat side facing back.
12.Also, make sure your bobbin is in correctly
13.the upper tension disks of your machine are threaded correctly.
14.Make sure the presser foot is up when seating the thread through the upper tension.
15.Turn the handwheel towards you only and hold the needle thread lightly.
16.could be a timing problem
1611
Feb 25, 2016 | Bernina BERNETTE 65 Mechanical Sewing...
How do i fix the top thread just tangling, looping on the shutter race?
1. Make sure that you are using the right bobbin case. (LX3125) 2. Adjust the tension of the bobbin case. (I've sent a guide for this) Your's is considered the older style.
3. Make sure the bobbin that is used is the right one. If it is too long or too wide it will cause problems.
4. When you insert the bobbin case make sure the lock handle goes down flat with the bobbin case. Also, feel the bobbin case for rough snags.
5. Replace the needle. Insert it the new one in the right direction.
6. Thread the machine (while pressure foot up) according to the directions. While threading give small tugs to check for snags.
7. Place the tension on four. It is ok to feel by hand if this is excess tension.
8. While turning the hand wheel towards you the bobbin thread should rise above the throat plate.
9. This should be ok now. Try it on some old rags. Don't forget to set that bobbin case.
Jun 08, 2015 | Brother LX3125 Sewing Machine
How do I reassemble drop-in bobbin case for Brothers XL 2600 free arm?
Do you have some pictures of the area involved. I know how to put these things back but I can't think how to explain it to you.. pics might help me show you.
Brother has an outstanding service department, and if you don't have a manual, they should have one. Should have a pic of how it goes together.
Aug 02, 2014 | Brother XL-2600
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
Error code c4
try these suggestions
try changing the needle
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help then the machine needs to be checked
Oct 06, 2012 | Singer 7258 Sewing Machine
Thread is getting tangled in the bobbin chamber of my brother xl3125 when I sew. When I pull the fabric out, several strands come out of the bottom and the bottom side of the sewing is tangled and loose. ...
change the needle
rethread the machine top 7 bobbin ---make sure the presser foot is in the up position before rethreading--use every thread guide
clean under the needle plate & in the bobbin area for lint
make sure the thread has not come off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case & that
the bobbin is not over full
Sep 27, 2012 | Brother Sewing Machines
My needle keeps coming unthreaded. HELP please
1) Open the needle plate and bobbin case and make sure the tangled threads are removed.
2) Open the manual; read and follow every step.
3) Thread the machine with the presser foot up - this is often overlooked and causes loopy stitches that pull right out.
4) Make sure the bobbin in inserted so the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
5) Take hold of the needle thread and lower, then raise the needle to pull the bobbin thread up through the needle plate. Take both threads under the presser foot and to the back of the machine.
6) When you come to the end of the stitching, make sure the take up lever is at it's highest position. This will keep the thread from coming out of the needle when you begin to sew.
I hope this will help and you will soon be sewing.
Mar 10, 2010 | Sewing Machines
Needle's thread gets tangled in bobbin
First, open the needle plate and make sure the bobbin area is clean and free of lint and thread.
Check the needle to make sure it is not bent and is properly inserted into the holder - usually with the flat side facing to the back of the machine.
Refer to your manual for bobbin insertion to be sure the thread is feeding from the bobbin in the correct direction and through the proper guides.
Always thread a sewing machine with the presser foot up. This opens the tension control and allows the thread to properly enter.
When the foot is down, the tension control closes to the sewing setting and if the thread is not in place, there is no tension on the thread and it gets loopy.
After threading, lower and raise the needle while holding onto the thread tail. This will pull the bobbin thread up through the needle plate. Take hold of both threads and take them under the presser foot and to the back of the machine.
Hand walk the first stitch when sewing and this should keep the top and bottom thread from tangling.
When stopping to change the position of the fabric (turning a corner, sewing a curved seam for example), do so with the needle down into the fabric. This not only anchors the fabric so it does not slip, but prevents mis-stitching.
If you are doing everything according to the manual and are still having a problem, the machine may need to be professionally serviced.
Feb 23, 2010 | Elna 1010
Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Oct 27, 2007 | Sewing Machines
Janome 405 Mechanical Sewing Machine Logo
82 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
