Question about Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF250
THE LED LIGHT FOR THE 'DOOR LOCKED' DOES NOT COME ON, ONCE YOU CLOSE THE DOOR AND AS A RESULT THE WASHING MACHINE ISN'T WORKING. IS THIS A PROBLEM WITH THE 'DOOR INTERLOCK' OR AN ELECTRICAL FAULT?
  • Anonymous Nov 18, 2007
    With my FX 1365W washing machine -When pressing start the red indicator light in the door doesnt come on and there are several cluncking sounds from behind the door lock followed by the beep code (4 beeps) for door not closed but the door is secured
Washmashine hotpoint wf 321 its start working prewash and not change the program ror wash and spinning
when start some smell come out i check inside and i find interlock is burn
i want ask if i change interlock i sort the problem? please let m e sort that problem thank you
kjszu79@gmail.com
Posted on Jan 24, 2011
It may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Posted on Nov 17, 2007
Hotpoint 6kg washing machine Aquarius wash light indicated door lock indicator flashing machine won't fill any ideas thanks Brendan checked filter ok
Many or even most washing machines will not run if the door lock switch is not working. Open and close the door a few times to see if the light stops flashing. You could press on the door where the latch is and see if that makes a difference.
Jun 04, 2015 | Hotpoint Washing Machines
Hotpoint WD640 Door Lock Light not coming on
check the door peg is not loose or it is the door lock
Apr 22, 2014 | Hotpoint Aquarius WD640 Front Load...
Have a Hotpoint WF250 washing machine. Fitted new door lock switch, but door lock LED now constantly flashes & washing cycle does not start, even though water pump clicks!
TRY CHECKING YOUR MOTOR BRUSHES.IF THEY ARE OK IT IS PROBABLY THE PC BOARD LOCATED AT THE BOTTOM RIGHT OF THE MACHINE AS YOU LOOK FROM THE FRONT
Jun 05, 2013 | Washing Machines
Door lock light will not come on even though door locked and hence no programmes will start hotpoint wf250
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Fitting pump to hotpoint WF250
disconnect the machine hoses and all drain put it on its side you will see the pump usually help in place by 2 screws/ 2 hose clips/ 2 wire thats it pump should cost no more than approx.18.00
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius wf250 won't do anything it lights up with wash symbol but doesn't fill or wash it doesn't make no noise or anything please help
open the top of washing machine and near the door on right side is a connector loose just push in and will work fine.
May 10, 2009 | Washing Machines
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wf 250 aquaries
try changing your water valve this should sort problem
Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
679 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
