Question about Saeco V-spresso Espresso Machine
Recently, the amount of coffee has decreased significantly. I have tried cleaning and adjusting the settings with no luck. It seems like there is water that is being emptied into the overflow tray even after it has finished the rinsing cycle, and has been emptied. I have emptied the tray completely and then dried it out just to see if the water is leaking from somewhere. Just making a single shot of espresso barely coats the bottom of the cup. But then when I pull out the tray, the water has collected in there again. I have had this for several years, but have never had an owners manual. I don't know what to do. Please help, I need and love my V-Spresso!!!!
  • 4 Answers
Follow the instructions to Descale the machine. I have the same machine and also found the Grinder works best at 12.
Posted on Jul 13, 2009
    President:
  • 1,618 Answers
Try adjusting the coffee grind to something coarser.
Posted on Jul 10, 2009
Only one spout dispenses coffee
Same for my CVA 5060 : the right spout seems to be blocked...
I tried a cleaning cycle and a descaling one with no success.
Any idea of where to clean ?
Apr 13, 2014 | Miele Coffee System
Ice maker, "water flow adjustment" tool
That is an Allen wrench, just buy a cheap set of them at the hardware store.
Mar 25, 2017 | Kitchen Appliances - Others
My coffee is to strong
You can change the coffee dose that you put in each cup by lifting the cover on the bean hopper (where you put beans), turn the dose knob (small knob closest to front of machine) clockwise to decrease the amount of coffee used for each cup. Set the knob and then press the coffee button. Gradually decrease the dose until you find the taste you like.
Sep 25, 2010 | Saeco Spidem Villa
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Rancilio Silva - coffee lost its punch
Try backwashing the group with purocaff.
Are you using coffee ground at the store or do you grind just before use?
How fresh is the coffee less than a month or more?
If more than a month(whole beans) it is no longer useful.
If more than a 3 days(ground), that is stale also. It will be very diffucult to get good espresso from that(not impossible, but difficult).
If using store ground, it cannot be ground older than a week(coffee loses flavor and taste minutes after being ground). Try getting less coffee more often and adjust the grind setting that you use. If you have always used setting 3 on the store grinder try 2.5.
If grinding at home adjust the settings on the grinder to a slightly coarser grind and fill the portafilter slightly over the top of the basket, now tamp to the indent(fill line) in the basket. that should be sufficient to pull a great shot.
May 17, 2009 | Rancilio Silvia Espresso Machine
Waterflow/heat seems fine - but little/no extraction
Try running the gro;up without the portafilter in place, what does the water flowq look like: is it a nice strong flow or barely a dribble. If if is barely a dribble, backwash machine with purocaff and check shower screen, that may be clogged. If you have a nice flow then try adjusting the grind on the coffee grinder.
May 09, 2009 | Rancilio Silvia Espresso Machine
WEAK espresso from Saeco Vienna!
Well, when you set it that low it allows the water to pass very quickly and if the water passes very quickly there may not be sufficient time to absorb the coffee; hence weak coffee. The setting should be reset to the middle, at 10, and tried again. Then, if you want to change it move it only one or two numbers for enough cups to see if there is any change before you move it a large number. Going higher or lower makes it pass more or less quickly with results accordingly.
You may also have the dose set too low and you may want to set it higher increasing the amount of coffee in each dose.
Then again, since it was used, you don't know if the machine was taken apart by someone who reinstalled the machine with the dials you are using out of whack with where they should be set.
George W Conrad.
Apr 02, 2009 | Saeco Vienna Espresso Machine
Saeco V-spresso Espresso Machine Logo
126 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
