Question about Garden
Engine problem I have a Craftsman Riding Lawn Mower. It has a 19 horsepower engine. My problem is that it will not run unless the choke is pulled all the way out. I need to know what to do to fix it so that it will run with the choke disengaged.
  • 376 Answers
Most probably there is a restriction of gas flow in the carb from varnish, trash or rust. The carb need to be cleaned/repaired.
Posted on Jul 03, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
My craftsman riding lawn mower only runs with the choke pulled out
You have fuel restriction . Unhook the fuel line from carb. Should run out.
May 15, 2013 | Craftsman Garden
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
Riding mower turns on when the choke is pulled but turns of when the choke is pushed back in. Sometimes it stays on but after a few minutes sounds like it is running out of gas and eventually turns off.
When were the air filter and fuel filter last replaced? Those are the two suspects to cause your problem and unless the mower is pretty new, or they were replace in the last year or two, start with those.
Aug 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blowing oil out mufler
Very common problem you have here
Try this when running the mower be sure that after starting you pull the throttle lever back a bit so that you are not in the choke position
IF you are choking the engine you will get oil **** through the engine and sooner rather than later oil in the muffler
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a craftsman 18.0hp riding lawn mower. Has a
Most likely it is the governor spring but you could have a stiff throttle shaft or a needle that is not closing properly allowing the carb to flow too much fuel into the engine.
Sep 20, 2009 | Garden
Craftsman Riding mower won't stay running
Well this could be a couple of things first thing first is check the air filter and make sure its clean you can blow it with air or pore gas over it and clean it make sure you let it dry before reinserting
second im assuming this is the first time you have used it this year if so the gas you have in it hasnt been sitting in it all year has it like anything else gas gets old
third alot of times you can let it run for a while with the choke out then slowly pushing it in
fourth you could have water in the gas remove the tank and empty it remove the spark plug turn the engine 4 or 5 times only bumping it dont hold it down this will blow some of the water out then dry the spark plug off and replace it
if this doesnt help it could possibly be carburetor problems
Apr 29, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 16 hp 42 in. riding mower won't run when clutch is released
If the engine feels like it is being choked, then something might be catching or bound up...for example the blades may have been installed improperly and will not rotate. Make sure that you can rotate the blades by hand...if not they may have been tightened and are binding against the mower housing.
If there is no engine choking...then it may be electrical for example a bad fault switch...take it to your mower shop.
good luck
Sep 27, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
