Asus K8V SE Delux
I have the above Motherboard and a Segate Ata drvie but the motherboard cant see it as the only HD, it installed it with segate utility when used as a second drive, but to use it as the primary drive and only hd, i cannou use the segate utility because the pc has to be booted, this board has 4 sata connections 2 used as raid, but it wont function
  • 46 Answers
Try to see in the bios, which is the boot sequence. It could be IDE first and SATA second.
Change the SATA to first.
Or see any option that talks about the boot sequence.
Posted on Nov 10, 2007
I just want to know whether SATA 1TB hdd support Asus K8V SE Deluxe Motherboard or not? and also i want to use 512 MB grafix card. can both things support to this motherboard?
Yes as long as there are SATA ports on the motherboard it will work fine.
You will need to find out if your graphics card is pci-e or agp and make sure it matches the motherboard.
May 03, 2011 | ASUS K8V-SE Deluxe Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Jan 27, 2011 | ASUS K8V-MX Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
Failed segate drive need replacement solution
Yes the ATA-300 is compatible with notebook computers.
I use Hitachi HTS7210 80GB.
Oct 07, 2009 | Seagate (ST9402113A) 40 GB ATA-100 Hard...
ASUS M2N MX SE Motherboard
Check the BIOS settings at boot up to see if you can select the primary hard drive there. Several motherboards have this option and it's buried in the boot settings. Let us know how it works out and good luck...
Jun 18, 2009 | ASUS M2N-MX Motherboard
Segate SATA HDD Cannot perform properly
Go to BIOS at machine startup. check the device, make sure hte SATA is set not at IDE.
Apr 09, 2009 | ASUS K8V-X Motherboard
I have a SATA M Hard drive and I would lke to add two ATA HDrives
As long as there is an empty IDE port you can. You will probably have to go into the bios settings after you hook the other drives up & set the boot menu to boot from the SATA drive 1st.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
Could not detect HDD on my Asus P4B-M Motherboard
try removing with jumper behind the hard disk. and the see the cable or plugged in properly and do automatic detection of Hard drives in Bios
Dec 22, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
