Question about Grilling
Grill fire I replaced the burners and regulator to my genesis grill. The plastic surface that housed the knobs caught fire. what next?
    Scholar:
  • 127 Answers
Check to see if the flexible tubes from the burner assembly to the gas valves are clear, undamaged, and completely seated on the burner valve orifices. If these tubes are only partially seated at the valves, gas can leak and ignite under the control panel. If this happens, the control valves can be damaged creating a serious fire hazard. If in doubt, replace the control valves.
Posted on Jul 07, 2009
Our weber grill is suddenly getting too hot... even with only 1 of the 3 burners turned on it is over 400 degrees... any ideas?
Sounds like the regulator is not controlling the flow of gas. Try this. 1. Turn gas tank and burner control knobs off. 2. Turn tank valve on VERY slow. 3. Open front burner knob on and lite grill. Wait a minute and turn on addition burners, (if needed).
Apr 27, 2010 | Weber Genesis Silver A Grill
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
The grill only reaches 200 degrees
PROBLEM
Barbecue temperature only
reaches 250° to 300° in the HIGH
position.
CHECK
The excess flow safety device,
which is part of the barbecue to
cylinder connection, may have
activated.
CURE
To reset the excess flow safety
device turn all burner control knobs
and the cylinder valve OFF.
Disconnect the regulator from the
cylinder. Turn burner control knobs to
HIGH. Wait at least 1 minute. Turn
burner control knobs OFF. Reconnect
the regulator to the cylinder. Turn
cylinder valve on slowly. Refer to
“Lighting Instructions”.
http://www.weber.com/manuals
Sep 07, 2009 | Weber Genesis Silver B Grill
Grill does not heat over 250 degrees
Here is a couple of things to do.
Make sure your tank is filled.
Straighten Fuel hose, so it is not bent or kinked.
Does your front burner light with a match? If it does light then check the Crossover Ignition System.
Also, It could be the way the unit is turn off.
Try following thses steps, this will help to reset the excess flow safety device.
Turn all burner control knobs and the cylinder valve OFF.
Disconnect the regulator from the cylinder. Turn burner control knobs to HIGH. Wait at least 1 minute. Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve on slowly. Then go ahead an light your grill.
Fireplace-girl
Jul 22, 2009 | Weber Genesis Silver C Grill
Low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Jul 03, 2009 | Weber Genesis E-320 Propane Grill
My grill does not heat beyond 300 degrees.
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly. I HAD THIS PROBLEM JUST LAST NIGHT AND FIXED IT RIGHT THEN.
May 22, 2009 | Weber Genesis Silver A Grill
May 19, 2009 | Weber Genesis Silver B Grill
Gas grill
Probably 1 of 3 things:
Check your LP tank valve at an LP filling station. Make sure both valve and tank are in working order.
Next check for webs or cocoons up around where knob valves go into burners. You may have to remove burners to see into back of valves. Then swab orifice holes with a torch tip cleaner.
Third, a Menards , LP outfitter/station, or grill shop should have a universal replacement rubber gas line and "regulator"(possibly plugged or stuck shut). Sometimes you end up with cheap/bad regulator out of the factory.
Good luck and hope one these helps or does the trick.
Mar 25, 2009 | Weber Genesis Silver B Grill
Grilling Logo
191 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
