Question about Kenmore Dryers
I have a kenmore stackable washer and dryer no heat is coming out. but it goes around
  • 867 Answers
The heating element is most likely fried, or thermostats need replacing
Posted on Jul 03, 2009
Kenmore dryer stackable unit, no heat coming from dryer, all else works
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Stackable washer & dryer Model # 417.93702200 and my dryer will come on and spin but it doesn't get any heat to dry my clothes. what could be the problem? Where can I get the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
Change thermostat, tested heater coil, dryer still won't heat on a Kenmore stackable
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Apr 16, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Dryer spins but wont heat - element okay
HAVE YOU CHECKED THE MAIN FUSE FOR THE DRYER?WHITE AROUND THE SIDES AND DARK IN MIDDLE,UNSCREW THE KNOB COUNTER CLOCK WISE TO REMOVE KNOB,SHOULD BE 2 SCREWS HOLDING TIMER REMOVE THEM AND THE PANEL SIDE SCREWS,THANKS-MIKE
May 29, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
115 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
