Question about Dolphin Maytronics Advantage
My dolphin diagnostic cleaner for my below ground pool, just stopped after years. I went to turn it on yesterday and there is power to the power box as the light goes on, but the unit is not moving. I am assuming it is electrical?? Could it be a fuse?
    President:
  • Dolphin Master
  • 1,378 Answers
If your unit has a fuse it will be on the back side of the power supply. If the light on the power supply switch is on, it will not be the fuse though.
Try turning the cleaner upside down on the deck and connect it as you otherwise would. Power it up and it should go through a self test process that takes about 40 seconds to complete. If it turns the tracks in both direction with and without the impeller turning, it is fine and will likley start working in the pool again.
If not, contact us through www.arrowpools.net and click on the FAQ and then Dolphin cleaner catagory. You can also use the Dolphin Serice button for information about sending it in for repair.
Posted on Jul 04, 2009
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
Dolphin diagnostic motor replacement
May be the circuit board - There is an on-line group called Circuit Board Medics who can test and repair the board.
Jun 22, 2012 | Dolphin Maytronics Diagnostic Robot...
Stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
Jul 10, 2010 | Dolphin Maytronics Diagnostic Robot...
Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
May 23, 2010 | Smart Pool Inc Dolphin Diagnostic...
Runs slow then stops for no apparent reason
You can contact us at www.arrowpools.net for service. There is also a FAQ for Dolphins in the FAQ section.
You can also try the manufacturer at www.maytronicsus.com for answers. It may be the power supply but is more likely an issue in the motor pack. It may still be under warranty depending on the purchase date and model. Some have 3 year motor warranties.
Jun 30, 2009 | Smart Pool Inc Dolphin Diagnostic...
DOLPHIN DIAGNOSTIC AUTOMATIC POOL CLEANER STARTS AND STOPS
There may be moisture building up inside the motor housing. Try to Open it. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Maytronics-Dolphin-Repair.html
Then make sure no moisture accumulated in the circuits. Mine got the same problem.. after running trouble free for several years it suddenly stop running after the first few minutes..when i opened it a lot of moisture in the circuit. I tot it was toasted. so i took my hair blower and sealed it back and replace the moisture absober (it was soaked).. after first run it would run only the SELF TEST mode.. i tried several method to make it run all the way to the main program.. the solution.. start it and make sure it will not tilt in the first 10 minutes before you let i run sideways to the walls, this makes the program run back to normal.
Jun 28, 2009 | Smart Pool Inc Dolphin Diagnostic...
Dolphin Commander goes forward 2' then back 2' then stops.
The impeller motor is likely worn out. New motor units are expensive but less so than a whole new unit. You can send it to us in Michigan at www.arrowmotor.net or find a closer service center using www.maytronicsus.com Good luck.
Jun 14, 2009 | Smart Pool Inc Dolphin Diagnostic...
Circuit board inside power supply is bad. I need a replacement
You'll need a replacement board. You'll need model and serial numbers off of the cleaner itslef to help identify which power supply and therefore what PCB is needed to replace yours. Try contacting our service center at www.arrowmotor.net and click the contact button in the upper right corner.
Jun 13, 2009 | Smart Pool Inc Dolphin Diagnostic...
Dolphin Maytronics  Advantage Logo
1,944 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Marvin
Marvin
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
