SHARP 29" TV switching off to Standby
Hi. I have a SHARP TV about 8 yrs old that switches off to Standby mode after using for about 20-25mins each time. Then it could not turn ON and stayed at Standby mode (even using remote or just push OFF then ON button - still back to standby mode). After about 15-20mins later I could switch on again by either using remote or push button. I checked all timer functions and there are no timer or lock that activated at all. Everything was as before. It just has this trouble of switching off and stay at standby mode after 20-25minutes of usage. Is this something that can be solved easily? What are the likely faults? Please advise.
  • 1 more comment
  • tanny Nov 10, 2007
    I tried changed the batteries of the remote control but it did not help. I now used the push button instead and it still switched off after some time. Seems like it is the detecting circuit/device that detected some problem after the TV is ON running for some time. I tried to get a more accurate timing and realised that it can sometimes last 50 mins or otherwise it can range from 20 to 30 miuntes. Is this a proble of the power supply regulator dying capacitors or due to some dry/cold solder (fatique joints)? Can soeone advise.
  • tarkaston Dec 14, 2008
  • Anonymous Mar 19, 2014
    There should be a code or some sort of trouble shooting for this fault
  • 34 Answers
Have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Posted on Nov 10, 2007
  • simon philips
    simon philips Nov 10, 2007
    continuity test the PSU (after cap discharge) will tell you if you have any dry joints mate
LG 29" COLOR TV HAVING MODEL NO. RF29CA40 plugged in and switched to standby mode it starts making a clicking sound. I can't get it to switch on it just sits clicking away in standby mode
my tv exactly same problem , from what ive read our tv 's are not worth the ammount it would cost to fix , around 250 dollars, im gutted! il let u know when i find out properly
Sep 19, 2013 | Televison & Video
TV switching to standby
Hi.i had exactly the same problem with my bush 37 inch lcd tv and i took it to a friend of mine who is a t.v electrician he said it was a component in the back of the tv which he replaced and its now working fine.
Jul 05, 2009 | Televison & Video
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Problem with SHARP AQUOS LCD TV - LC32GA6E: It switches on by itself!
Is the remote in the room and pointed at the tv when this happens? If it is try fresh batteries in the remote.
Jun 12, 2008 | Sharp Televison & Video
I have a sharp aquos l-c 15b6u will not come on.There is red light showing power when you touch switch for on position light is not going green tv will not come on
How old is the TV? Generally when the Red light is on and the TV will not turn on or go Green means it is in protect mode or standby and needs to have repair done to it.
May 09, 2008 | Audio Players & Recorders
LG CT-29K30EX 29" TV plugged
LG CT-29K30EX 29" TV - We have the same symptoms as described. If you are a person who is not afraid of opening the back cover of your TV and replacing parts inside. this tip is for you. Contact a service person if your not 100% sure. Its actually easy, it involves replacing a small capacitor in the power supply section. You don't need to troubleshoot coz i've done that for you for free. Find this capacitor in the power supply. C801 with a value of 100uf / 35V. De solder and replaced it with the same value or a much higher Voltage rating e.g. 50V. Done! your T.V. is alive again. - Rey Tilles - New Zealand
Apr 06, 2008 | LG Televison & Video
Sharp TV switches to "input 2"
There's an option on the menu to tuen 'demo mode' on and off. If it's set to on, that's your problem. It will be switching input sources every 2 minutes or so. Switch this off and it'll be ok again.
Feb 13, 2008 | Dual XDVD8181 Car Video Player
Panasonic switching to standby mode on its own
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
Oct 05, 2007 | Televison & Video
Sharp 34" TV
Why shouldn't it be worth fixing? It's only 4 years old, my own TV is 15yo, I fixed it twice but it's still kick'n! You have a problem in the power supply, do you have electronic's know how? And test equipment? Soldering equipment? If so we could walk you through it, If not A repair man should only cost 80 to 100 to fix it.
Aug 13, 2007 | Sharp 32C-240 32" TV
Televison & Video Logo
445 people viewed this question
Top Televison & Video Experts
