Remington Fire Arms Company built a Model 700 rifle wqith serial number A6403542? What year was it manufactored?
SOURCE: where can I get a manual for a springfield j.
http://www.e-gunparts.com/aboutschematics.asp
See if this site has what you need.
SOURCE: I want to find the year my Model 99, Savage was
http://www.savage99.com/ is a great amateur website containing a lot of information about Savage Arms.
According to their database, your Model 99 dates from 1941.
SOURCE: My Remington model 7400 semiautomatic 308 rifle
All Remingtons of this type have this problem burnt powder and oil mix to stop everything up but it is an easy fix, Remove the two push pins that hold the trigger group in and pull trigger and all out. put it in a container of kerosene and let it set over night take it out and clean it up good and put it back in. It should be good as new
SOURCE: How old is Remington model 572 Fieldmaster rifle
The serial number does not reflect the date of manufactuer, but there are letters stamped in the side of the barrel at the reciever, on the left side, they are a date code, I will give you an app, If there are more than a couple letters and numbers, it has been reworked by the factory. But none of mine have.
m=1921,,,z=1931,,, and all the letters in between there except for o and q are the years, then it starts again at A=1932, and goes to L=1942, then,,,MM=1942,,,NN=1944,,,etc to ZZ=1953,,,then it stats with A again,,through Z= 1975 and after that it a random of letters I,O, Q and V, to 1979, then A, again, to Z=2005, then it starts again. hope this helps.
SOURCE: I have a Savage Arms Rifle Model 6 DL-N looking for a serial number and date ?
It should be on the barrel
