Question about Black & Decker Hedge Hog Cordless Hedge Trimmer
How to rewind spool with lineon my hedgehog trimmer
  • 313 Answers
SOURCE: Trimmer won't run - B&D CST2000
could be loose connection in the motor due to vibration.
Posted on Jul 09, 2008
  • 313 Answers
SOURCE: Can't find spool replacement AF-150-04
not sure but .065 maybe
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
  • 4 Answers
SOURCE: 18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Posted on Aug 07, 2008
  • 6 Answers
SOURCE: at home depot I can purchase .065 line without the
It is fairly easy to restring trimmer. just follow the arrows on the spool.
Hope this helps
Tobaz
Posted on Jun 17, 2009
REWINDING LINE ON MY ECHOSRM211 WEEED EATER
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ~~
Feb 14, 2012 | Garden
Poulan25cc 16 inch how do i rewind trimmer line on my poulan 1500 gas trimmer
You should wind it on the spool the opposite direction that it spins while operating it. If you wind it in the same direction as the spin, the line will come off the spool when in operation.
Jim
Jul 29, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
How much line is required to rewind spool and instructions on how to do
45cm of cord, threaded through the spool and knot tied in the end,then back through the casing and put the handle on.
Jul 14, 2011 | Husqvarna 28cc Gas Line Trimmer
Having trouble replacing trimmer line
Hello. I just answered a similar question not twenty minutes ago. Hope this helps.
Please read all the way through this before beginning to actually rewind the spools.
1. Pull the spool off of the head. Clear the dust and debris out.
2. Note that it is actually two spools that are separated by a disc, and that the disc has a slot in it. The outer spool is the spool closest to the bump head, and the inner spool is the one that fits closest to the machine and has notches in it. If you turn the spool so that the inner spool base is up, you will see that there are decimal numbers next to the notches. The decimal numbers are your line size(s). I say sizes here as some machines will accept more than one line size. You will also notice arrows on the inner spool base, telling you which direction to wind the line on to the spool(s).
3. Wind the inner spool first: Put the end of the line into the hole that is in the core of the inner spool. insert ~1/8". Wind in the direction of the arrows until you get roughly even with the divider between the inner and outer spools. You want to end up with your line 180 degrees from the slot in the divider, and snap the line into the notch that is in the inner spool base. You want about 6" of line beyond the notch. Cut the line, leaving a 6" tail.
4. Wind the outer spool: Wind the outer spool like you did the inner spool, filling the spool as before, and ending at the slot in the divider. Feed the line through the slot and snap it into the notch. Cut a 6" tail as before.
5. Reinsert the spool: Get the spool close to the machine. Insert the tails into the grommets in the head, and snap the head into place.
6. Preparing the line for use: Push the spool in as if you were bumping it against the ground to advance the line. Grab the tails and pull. This will release the line from the notches, and should release about 1" of line in doing so.
You should be good to go.
Every so often, it's a good idea to put some graphite dust into the spool just before putting the spool back onto the machine. This helps when you are advancing the line. I do this every 8 to 10 times I rewind the spools.
If this fails to correct your problem with the spool, it would be best to purchase a replacement spool.
Best regards, --W/D--
Jan 31, 2011 | Tanaka 22" Double Sided 24cc Hedge Trimmer
The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
How do i rewind huskavarna weed trimmer
on the spool there is a direction arrow showing you which wat to thread spool, each is in opposite position. If you do it the same way it will tangle
May 29, 2010 | Husqvarna 28cc Gas Line Trimmer
Line will not advance line is not crossed in spool
Rewind the line and make sure you wind in the direction of the arrow on the spool. Not an unusual situation.
Mar 31, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Apr 09, 2009 | Garden
Black & Decker Hedge Hog  Cordless Hedge Trimmer  Logo
196 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
