I need instructions for operating a Sears Tower slide projector, Automatic 500,
5 Suggested Answers
  • 412 Answers
SOURCE: Automatic slide changer is stuck in
The problem is continuous cycle (like you don't know that already...). It indicates that an adjustment to the cycle contact is necessary. To open the projector, first unplug it and remove the lamp module from the rear of the projector. Turn the projector upside down. Remove the 6 - T15 TORX screws from the bottom (5 around the perimeter and one in the channel next to the cord wrap). CAREFULLY pull the bottom off (the power wires connect the bottom cover & top together!!). Once you have it open, leave the projector upside down, put on your safety glasses & plug the projector into the wall. At the center of the projector you should see a hub rotating about every second or so. Above it you should see a "J"-shaped wire. See the attached illustration.
You will have to, in repeated steps, unplug the projector, bend the "J"-shaped wire GENTLY & SLIGHTLY, plug the projector back in and cycle it a few times. Check for the position of the "J"-shaped wire to the pad, and GENTLY repeat until you achieve the position shown in the illustration.
Posted on Dec 30, 2010
SOURCE: operating instructions
Go to www.Gevalia.com customer support. They have the manuals there.
Posted on Aug 21, 2008
frankgilbert
  • 613 Answers
SOURCE: Need new bulb for old
The only place to get it is online. I used this link from bulbs.com
http://www.bulbs.com/eSpec.aspx?ID=12053&Ref=Light+Bulbs%2c+Ballasts%2c+Fixtures+and+More&RefId=0
Posted on Jan 03, 2011
  • 13 Answers
SOURCE: I have a sears easi-load
I have a number of these. The printing on the box is as follows:
For use with Sears 9833, 9843, 9853, 9854, 9883, 9884, 98833, Sawyers, GAF and Anscomatic tray-loading projectors.
Posted on Oct 03, 2011
How to load a Sears du all 8 1973
Sears 8mm projector with 1950's & 60's films - YouTube
? 13:24
https://www.youtube.com/watch?v=7-IIS8ti7Ig
Jul 5, 2011 - Uploaded by drh4683
Vintage sears automatic projector. ... All 8mm and 16mm movie film, even going back to the 1920's and 30's ...
Sears Du-all Eight - Demo - YouTube? 0:37https://www.youtube.com/watch?v=WHbqCMKUGkoNov 13, 2007 - Uploaded by fierorcr86Buy This Now at www.mycurrentauctions.com I demo a Sears Du-all Eight super 8 ... How to load a Bell ...Sears Du-all 8 auto thread projector - YouTube
Jan 01, 2016 | Office Equipment & Supplies
45 year old Slide projector
Ask around your local photo shops for a guy with a long grey beard to ask.
You could try advertising for an instruction book on your local freecycle and if Hanimex is still in business they might help you.
Some of those slide projectors were intuitive as they were completely manual but there were also magazine load, semi-auto and fully automatic versions that could also have a recorded commentary and backing music synchronised to the slide show.
Best of luck friend, have lots of fun with it.
Sep 04, 2015 | Office Equipment & Supplies
I need to know how to use a argus 500 slide projector
I found several manuals on eBay when I searched on Google using the projector brand & model name.
Aug 17, 2013 | Office Equipment & Supplies
Sears tower projector jammed up. Need to know how to access the stuck slide
This should help
Apr 04, 2013 | Office Equipment & Supplies
I need the owner's manual for a Sears Du-all projector
I believe if you check out the "Manuals & Guides" section of Fixya, they have the manual there. I found many listings for it online, also. Jim
Oct 09, 2012 | Sears Du-all Eight 8mm Projector...
I just dragged this projector out of my grandma's basement. I have a new bulb and the projector appears to be in working condition except for the slide advance--the slides advance continuously. How...
There is usually a sliding tab on the side of the projector (behind the handle) that toggles between "manual" and "automatic" advance. (Some models will have a couple of pre-set advance settings between "manual" and "automatic." These usually advance the slides every three to ten seconds.) Push the tab to the manual setting--this will allow you to use the buttons towards the front of the machine to advance your slides.If moving the tab doesn't work it may be broken or jammed.
Jul 29, 2011 | Kodak Carousel 4400 Slide Projector
I have a sears easi-load circular tray 9985 for a slide projector. I don't know what brand projector it will fit in. Thanks.
Apr 30, 2011 | Cameras
The projector keeps turning as though it was is in a very quick timer mode when I power it on.
It is operating in "continuous cycle" mode. It's possible a contact on the slide change camstack has either worn out or an adjustment to that electrical contact point needs to be made. An authorized Service Dealer has the instructions to make this repair.
Oct 03, 2010 | Kodak Carousel 5600 Slide Projector
Need to make it advance automatically
Sure! Not only did Kodak sell an external automatic timer that plugs into the remote socket, a number of other companies had them as well. If you can't find one searching online for "Kodak slide projector plug-in timer", try: www.micro-tools.com Good Luck !
May 12, 2009 | Kodak Carousel 4600 Slide Projector
Need software
Try Windows Vista it sounds very powerful.
Mar 08, 2008 | Elmo Projectors TRV-35H Slide Projector
179 people viewed this question
 Grubhead
Grubhead
