Question about Nespresso C190 Espresso Machine
ORANGE INDICATOR KEEPS FLASHING
I have a Krups FNA2 espresso mashine that has worked prfectly for three years. This morning the orange light indicating the reservoir for the empty cups is full was flashing so I empties it. After I emptied the reservoir I put it bach in the mashine but the orange indicator is still flashing and won't stop. Result I can't make coffee. I tried reinserting the reservoir a number of times and cleaned the mashine thoroughly but the indicator flashes none the less. Can you help me?
2 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
Nespresso U - the lights keep flashing but doesn't work
have you done descaling try pressing the two buttons at the same time but keep holding them for 5 second tell me is it flashing fast or slow?
Sep 08, 2014 | Krups Nespresso U Xn250a40 Coffee Machine
Krups FNA2 doesn't draw water!
If it sounds like a pumping noise but louder then it may mean that the pump is bone dry and needs to be primed. You need to find an imaginative way to force water into the socket that the tank engages with. A clear hose of the correct size with water already in it and then press the button and blow into the other end of the pipe. Once the valves are immersed in water it should start to function.
Dec 18, 2013 | Krups Coffee Makers & Espresso Machines
The hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Dec 30, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Dead Krups XP2070
I think you are right. Most likely the power board at the bottom. I saw a post about replacing the transformer but I when ahead a replaced the power module to fix mine.
Jun 07, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP7200 wont grind beans (all lights flash)
See post on leaking xp7240. It is almost the same machine. This post explains how to fix it (valve is blocked but can be easily cleaned)
Mar 14, 2009 | Krups Small Appliances Espresso Machine
Not sure how to take it off cleaning mode. The cleaning button continues to flash?
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={EBDB947E-33FB-42E0-B662-0E13E8D1D4FB}&SelectedProdRef=XP9000
here is a link to the manual. u will need adobe to open it
Jan 20, 2009 | Krups Super Automatic XP 9000 Espresso...
Flashing red light
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
Aug 20, 2007 | Nespresso C190 Espresso Machine
Nespresso C190 Espresso Machine Logo
91 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
