Question about Bose Lifestyle 48 System
We tried to reset our system by unplugged the
We tried to reset our system by unplugging the power, but now the system won't turn on. It keeps flashing "Bose Lifestyle", so it has power. We wanted to reset the system becuase the AM/FM and AUX plug-ins weren't functioning, but the DVD player and the stored music center were. We had this happen once before and the reset worked that time.
  • mzabek Jul 03, 2009
    We have done as you suggested so hopefully in 24 hours we will have our system operating again.
    Thanks
  • 3,230 Answers
First of all you try a hard reset - remove all the cables connectors from the system and switch it off from main power plug for 24 hours.
if that not works than you try updating the Firmware of that from the following web site -
http://global.bose.com/index.html
if again you have the same problem than contact to Bose support (800-905-2138).
Good Luck!!
Thanks
Posted on Jul 03, 2009
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Thermaltake TrR2-430W power supply won't power on
Try to unplug it from the motherboard and put a wire between black and green wire and see if the fan turn on
if it won't turn on unplug all and open your PSU to see if the fuse isn't burned (ONLY IF THERE AREN'T WARRANTY)
Dec 13, 2012 | Thermaltake Computers & Internet
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
Computer ramdomly turns off
Instead of unplugging everything, only unplug 1/2 of the things. If it still won't start, unplug 1/2 of the remaining things (noting which ones they are). If it restarts then, it was one of the last set of things you removed that is the problem, so keep eliminating possibilities in this fashion this until you can determine which component it was. If it turns out to be the power cord, it could be a problem with the power supply.
Mar 02, 2012 | HP Computers & Internet
I cannot get my Lexmark 5600-6500 to turn on
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet. Wait at least 10 seconds before re-plugging the power cord into the power outlet in the wall (bypass any power strip) and the power adapter into the printer. This will give enough time for the printer to reset itself. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Can't turn on my go video dvd/vcr player, keeps
Unplug it, press the power button, then plug it in and retry it. If it doesn't work, unplug it, press power, and let it sit a couple days, to try to reset everything. There may be a reset pinhole in the back, unplug it and press the reset button.
Sep 15, 2009 | GoVideo Go Video DVD/VCR Combo
My acer aspire e500 has no hard disk aactivity
Try to discinnect CD/DVD driver also when you power on main cor dont instantly power on case, wait 5 minutes and then try. Such kid of failureas are causer by power adaptor system. Also try bios reset put off battery and wait 5 minutes to reset CMOS also power cord must be unpluged. Unplug and plug power sources to mainboard. then turn on.
Jul 30, 2009 | Computers & Internet
Unit keeps beeping even when unpluged. over load
UPSs will beep when unplugged to tell you that the mains is off! Overload should reset if you disconnect both the load and the power.
Jun 30, 2009 | APC Back-UPS CS 500 UPS System
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
Bose Lifestyle  48 System Logo
108 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
