SOURCE: Are all bunker hill safe keys the same?
Never!.............sodeep (unless you happen to be the lucky one in a million)
SOURCE: i bought a safe from a garage sale and cant poen it
I know Harbor Freight sells some of their products and you can download the users guide from their website it should help you get it working. Good Luck with it!
SOURCE: changing digital combanation on safe
Manual for bunkerhill safe , how to program and specs:
http://www.harborfreight.com/manuals/93000-93999/93575.pdf
No Known default combination.. Sorry!
SOURCE: bunker hill safe model no.45891 bought used, can't
Safe has Key lock hidden on it? Contact Harbor Freight with serial number, to try and get new key. Once opened follow these instructions at:
SOURCE: bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
1-800-444-3353. They are distributed by Harbor Freight. This may be their phone number. In any case, they have technical info.
http://manuals.harborfreight.com/manuals/45000-45999/45891.pdf
This is the manual.
Gary
