Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mtd mower will not start battery is ok
How do i troubleshoot it
  • 11,896 Answers
Check spark plug after you remove it and hook it up, lay it on engine and crank it. Make sure there is a good strong spark. If there is spark, then that is not the issue. If there is NO spark, the the coil will need to be replaced.
Check carberator to make sure it is getting fuel. They do tend to build up with gumm. and need to be removed and thouroughly cleaned with solvent and carb cleaner.
Posted on Jul 03, 2009
The back wheels are starting to go out they move some time but not all
Posted on May 12, 2010
My yard machines by mtd mower model number 11a-b13l029 won't start?
Fuel must be less that 30 days old! Air filter OK? oil level OK? Is the shut off cable streteched, If it is then is makes contact and will not allow the engine to start.
May 15, 2014 | Mtd 22" Yard Machine Push Mower
My' MTD riding mower will not start? the battery is fully change? but just will not started. when I check the oil? it was not good; it was very black, and the oil lever was very high above normal
can you rotate the engine by hand?try and bypass wiring and jump at the starter if ok they bypassing the safety switches and bypassing each battery cable
Apr 21, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mtd riding mower won't start clicking noise
Take some sort of 12V tester and measure voltage on the small terminal on the starter to ground. You should get close to 12 V with key turned. If you see the 12 V, test the incoming large battery terminal. It should also be close to 12V. IF that's ok, check the large terminal on the starter. If you have 12V here, then check for bad ground connection. If any of these are not 12V remove cable and clean connection. How are you sure the battery is ok?
Jul 23, 2010 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Mower will not start, battery cgarged up but onlhy
Check all the wiring connections on the starting system. Start at the battery. Both posts. Then, check where the ground goes to the body of the tractor. Make sure it's not rusty and making a good connection. Check the wire from the battery to the solenoid. If worse comes to worse, you can take a jumper cable and go from the battery + side and jump right to the starter post where an electrical cable connects. This will let the engine turn over, but make sure you have the mower in neutral and brakes set, with blades OFF!
Jan 28, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Mower wont start just clunks battery ok
SOUNDS LIKE YOU DUMPED SOME EXCESS GAS IN ENGINE,PULL PLUG(S) AND CLEAN OR REPLACE, CHECK CYLINDER FOR EXCESS FUEL BY CRANKING WITH PLUGS OUT,SHOULD SPIT ANY EXCESS FUEL OUT OF HOLE,REPLACE PLUGS AND TRY TO START.
Apr 08, 2009 | Mtd Garden
Mtd mower blows fuse when you try to start it
Pull the starter and have it bench tested. If it is ok then you may have an engine timing problem. ''Good luck. donnyb60
Mar 23, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
319 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
