Question about Admiral AW22 Top Load Washer
AEG W 1050 - Will not drain the water
I opened the filter cap and the water run out of the machine.
Why won't it drain using the pump ?
    Scholar:
  • 116 Answers
Pump or output hose is probably blocked or the pump impeller is broken, strip and see i'm afraid
Posted on Apr 13, 2008
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
My machine a Bosch excel vario keeps displaying E18 and flashes and keeps pipping I canot get the door open tried two washes
E18 indicates a time out draining.
I'm assuming it's stopped full of water.
Put the machine on spin only and see if it empties and spins.
After that you'll need to check it over.
It's very likely there is a blockage preventing the machine draining.
It can also be a faulty pump or control board but this is less likely.
It's a lot of work but try the following.
Check the drain hose where it connects to the house drains.
If onto a connection, take the hose off and check both for a blockage.
This is normally under the sink.
If ok, you'll need to manually remove the remaining water from the machine.
Put a shallow dish in front of the filter/pump cover. (Bottom front of the machine)
Slacken the cap a little to drain the water.
If there is a draining tube, use that to empty the water.
Tighten the cap to stop the water when you need to empty the container.
(If you pull the machine out and tilt it rearward, you can get a larger container in place for a while).
Once the machine is empty of water, take the cap off.
Clean out any debris in there.
Once cleaned out, take the laundry out of the machine.
With the cap off, put the machine on spin only. (If it resets).
Listen at the open filter to see if the pump is running.
(You should see the pump impellor rotating)
If the pump isn't running, let me know.
If the pump is running, refit the cap and try the machine again.
Good Luck
Feb 16, 2015 | Bosch Washing Machines
I own a lg turbo deluxe wf t7517te machine After the machine has washed the clothes it doesnt drain it Please fix my problem asap
Sometimes lint and other debris can collect in your drain pump filter. Keep things running smoothly by cleaning your drain pump filter occasionally.
  1. Open the drain pump filter cover by pressing on the center tab.
  2. Pull out the manual drain hose to the left of the filter cap and use a small bowl or pan to drain out any residual water (approximately 2 cups) that is remaining in the drain pump.
  3. Place a towel down on the floor to catch any left over water and remove the drain pump filter, by turning it counterclockwise.
  4. Remove any lint or items trapped in the filter by tapping it out into the wastebasket, and rinse it thoroughly with warm water.
  5. Replace the plug at the end of the manual drain hose and place it back into the holder. Then reinsert the filter into the drain pump opening and turn it clockwise to secure it back in place.
Apr 04, 2014 | Washing Machines
Aeg l14710. Hi can you help me made a decision on my six years old heavily used machine? each program can be set to show the program time but the machine will not start. the door locks. and the mac
Hello!
Probably you have foreign stuff in the drain pump or the pump worn out. Unplug the machine and unscrew the pump cap, watch for water pouring out, prepare something to catch in the water, then inspect for coins, knobs, ... . Check if the pump wheel rotates freely. screw back the cap and try to start a new wash program
Feb 24, 2018 | AEG Washing Machines
AEG Lavamat 16830 won't drain
The simplest way is to lay the washing machine on the right side so that you filter closer to the floor and from bottom of the washing machine is accessible drain pump. It can be fixed by three screws
or just turn pump counter clockwise and pull out.
Dado
Mar 29, 2017 | AEG Washing Machines
Dishwasher won't drain
If you hear the motor running when it is to be draining you may have a busted pump impeller. Also locate and check the round looking cap it will move up and down by your hand pull it up if it is stuck at the bottom this is your float level it goes up and down with the water level the pump will not switch over if it is stuck on the bottom if it is stuck it is telling the dishwasher it is empty of water. and last but not least your wash timer may be out.
Apr 07, 2012 | AEG 23 in. Favorit 44070Vi Built-in...
Hi, i have an AEG Lavamat 1100. Although the machine runs through the spin cycle, and shows the wash cycle as being finished, when i open the door there is still water in the bottom of the machine and the...
Hi bwileman435,
It may not be draining well, because it is dirty, did you clean the Drain Pump filter?
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | AEG Washing Machines
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
Feb 26, 2011 | Samsung Washing Machines
Clogged up. Washed rubber backed rugs and the rubber shredded. It wont drain. How do I clean it out?
¡æThe drain pump filter
The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Dec 20, 2010 | LG WM-2277HW Front Load Washer
HI, The machine displays "EFO"... We put the water out as described on your site but it seems the code "EFO" is still in memory (there is no more water inside, but each time we start a new program, the...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 15, 2010 | AEG Lavamat 88840 Front Load Washer
Admiral AW22 Top Load Washer Logo
55 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
