Question about Denon Audio Players & Recorders
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD recorder with Digital Optical output, 2 Scart and one S-Video output terminals. Samsung LCD TV' LE26R7 Room 2 Denon 1509 Samsung LCD TV' LE32R7 JVC XV-S300BK DVD player Optical lead connection exists I also presently connect the 2nd room TV with a co-ax cable run from the 1st room Satellite Digibox RF2 outlet, so I can change satellite channels with an in-line 'Magic-Eye' connector. I want to get surround sound in both rooms. Notes; Have an optical lead connection between the two rooms. Tried an optical splitter from the digibox to the two Denons, but does not work, will only operate each Denon by direct connection to Digibox. Tried AV sender but erratic reception. Have been advised about Balun s-video to Cat5 lead, to Balun into scart video on 1509. I'm now a bit confused and would like either a schematic ir description telling me what to connect to what in idiots language. Many thanks, Martin
  • windclipper Jul 03, 2009
    Room 1
    Room 2
    Denon 1509
    Notes;
    Many thanks,
    Martin
    Please read this carefully,
    Room 1
    Room 2
    Denon 1509
    Notes;
    Many thanks,
    Martin
  • 2,071 Answers
  • 11,896 Answers
You can use mulit scart, you could buy a multi scart box for around £20 . one end is a scart the other is a box that accepts up to 4 scart leads, but also try :-
digibox to dvdr via scart
dvdr to tv via scart
that way you are watching the digibox though the dvdr
Aerial in to "cable in" on Digi Box
RF cable from Cable out on Digi Box to DVD recorder
RF cable from DVD recorder out to TV
1xScart from VCR/Aux on Digi Box to DVD recorder
2xScart from Digi Box to TV
Posted on Jul 03, 2009
    Brigadier General:
  • 3,917 Answers
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Can you connection satellite sound to optical input
Yes you can run optical lead from sky box to receiver in the sky box setting you need to tell it that you are using optical and on the receiver u need to bind 1 optical with hdmi input this is done though input settings hops this help
Dec 21, 2013 | Onkyo TX-SR606 Receiver
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
New sky digibox fitted. Cannot timer record satellite programmes
I encountered a similar problem when recording and I phoned Sky and they changed my settings to eliminate standby mode for me.
No problem any more.
Mar 21, 2009 | Panasonic Televison & Video
TV and Sky hd to samsung HT-Z310
connect 1. cable/satellite box to TV with HDMI. 2. cable/sat box to sound system using optical cable. 3.change box sound setting to optical/dolby.
Jan 22, 2009 | Samsung HT-Z310T Theater System
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Aug 10, 2008 | Pioneer PDP-4270HD 42 in. Plasma...
Pace Sky plus box
You have 2 choices, software reset or hardware reset. It's up to you what you try, but please read the advice in full before starting - if you break your box, please don't blame me!
SOFTWARE RESET
The following is copied from http://www.ecademy.com/node.php?id=73309
This is useful if your disk usage percentage doesn't go down even after clearing programmesfilms off.
The following is offered on an ADVICE only basis, take care when making changes:
WARNING following this advice is totally at your discretion and anything which happens to your digibox as a result is your responsibility, not mine. You will lose all recorded programmes from your Sky+ Planner.
Sky tech support can talk you through performing a system restore over the phone. To do this yourself, press 'services' on your Sky plus remote, then select option 4. Next press 0, 1, select - you should now see the engineer's menu. Choose option 8, 'Full System Reset'. The box will now take a few minutes to reset itself
Try pausing or recording again, and if the problem persists disconnect the digibox from the mains power. Press and hold the 'left' and 'right' navigation buttons on the front of the digibox whilst you reconnect the mains power. Continue holding the buttons in for about 20 seconds, and when the ring of light on the front comes on, press the 'select' button on the front of the digibox (between the left and right buttons you were holding). The Sky+ recording logo lights will spin backwards and, according to the Sky engineer, this will "clear the hard drive".
Once this is done, disconnect the digibox from the mains power again and this time press and hold the 'back up' button whilst you reconnect the mains power. Continue holding it for about 15 seconds until 3 lights on the front of the box come on and you get a full-screen message saying "Updating system software. Do not disconnect mains supply or satellite dish."
Leave the digibox doing its thing for about 10 minutes and it should be fixed! Try pausing and recording things again... hopefully you've just saved yourself £65
If you've not been so lucky, you'll have to get Sky to fix it for you. Some people report that if you ask to cancel your subscription Sky sometimes offer a free callout to fix the problem - you're more valuable to them as a paying customer than the cost of an engineer callout
Sky customer service's (seemingly unpublished) freephone number. You need to dial 0800 731 6965, then option 2, option 4 March 9, Sky have closed this Freephone number
HARDWARE RESET
Copied from http://www.digitalspy.co.uk/forums/showthread.php?t=484098
Full System Reset via front panel:
  1. Remove power at mains.
  2. Hold LEFT+RIGHT.
  3. Apply power, wait for ring to light.
  4. Release LEFT+RIGHT, press SELECT.
  5. Ring cycles backwards while disk is quick formatted.
  6. If format sucessful PLAY lights up, if not RECORD lights up.
  7. Box goes into standby - wait 30 seconds are wake it up.
Warning: Full System Reset deletes all your recordings and planner entries.
Aug 07, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Jvc digibox
hi try turning the sky box on wilst holding the back up button in, wait till the on screen message comes up on the tv then let go of the button, wait till the message goes off the screen then try turning the sky box on if it dont then you will need a new box.
Jul 27, 2008 | JVC Audio Players & Recorders
Connecting the LE46A556P LCD TV to the HTZ310R Home Cinema System
You need to be connecting the TV and the Sky Plus to the HT box via optical (toslink) for full surround sound. As you only have one optical port on the HT, I would suggest buying a Optical selector such as this one. I would also suggest looking on avforums more more help. I use it for most of my questions if ever i need any help.
Hope this helps!
May 22, 2008 | Televison & Video
292 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
