Question about Microsoft Xbox 360 Console
360 turnson but no pic just sound
The coreds hooked up right switch on reagular tv
  • 767 Answers
This common problem .
there are about 9 solder balls connections
right under the G.P.U. Hot Spot and after repeated
heating /cooling cycles these connections began to
fatigue and break open giving you R.R.o.D. or freeing
white -green vertical lines ... and no video.
Solution is a proper x clamp mod and if
done right a most hardware error are
eliminated .
Posted on Jul 03, 2009
No game in box and on pic but have sound
does this mean that when u turn on ur xbox u do not see pictures but u hear sounds? If thats the case the tv is not switched to the right input or the video cable is defective
Feb 26, 2011 | Microsoft Xbox 360 Console
Can i hook up my xbox 360 to my aquos tv with just the red, yellow, and white cable? Right now I am not getting a color pic
Yes you can but it won't be Hi def. It sounds like you're trying to connect the cables to the Hi def input (Red, blue, green, white and red for the audio) That's not the right place to connect to.
Dec 28, 2010 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
My XBox 360 does not show up on the tv screen, but it has sound.
this happens a lot. what happend is the red white and yellow wires that you put in the back of your tv. the red one is not in the right area or
there is a switch right were you plug in that cable with the red whit and yellow cables to your xbox that says hd or normal switch that to whatever your tv is
Jul 17, 2009 | Microsoft Xbox 360 Console
I am using my xbox 360 via HDMI, and I have a 5.1 surround sound system hooked up via RCA output from the tv. If I switch it onto the coax input it works, but when I switch to HDMI it doesnt. Is there a...
no, there's no firmware upgrade that you can do on the tv. the reason for that is because you are sending digital sound to the tv with hdmi from xbox 360,and when you have rca cables connecting your tv and surround sound, the rca cables provide stereo sound. what you need to do if you want to use hdmi is connect optical cable from tv orxbox 360/ or tv to your surround sound to get digital sound, and it will sound better digital sound.
Apr 17, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Sound but no pic
One of the cables which gives you the picture will be switched on HD instead of just tv there a little switch on the side on the the cable
Mar 23, 2009 | Microsoft Xbox 360 Console
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Nov 15, 2008 | Microsoft Xbox 360 Console
High definition cable hookup
There is a switch on the 360 hd cables themselves it is a slider to go from TV to HD it is right where the cable plugs into the 360...switch towards 360 is tv and away is HD. Hope this is what you needed.
Feb 06, 2008 | Akai PT5250A Television
XBOX 360 no picture
try diffrent connectors composite instead of componant or vis versa. the wireless for the controls doesnt work on mine. I havent been able to find alot of replacement parts for the 360. I think you will end up having to send it in or by a used Core system for $200 from ebgames or ebay.. You could also try holding down the power button for 10 seconds. i heard that resets it as well.
Jan 18, 2008 | Microsoft Xbox 360 Console
Xbox 360
On your AV cord theres a switch that changes it from HDTV, to TV
Make sure its switched to TV if your not using HDTV, or switched to HDTV if ur using that. If you need pics let me know I can get you some so you can see where the switch is.
If that doesn't resolve it check your cords, make sure the cords match the colors.
Oct 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
78 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
