Question about Cisco 7910 IP Phone
Cisco ip phoe
Does anybody knows how to configure the cisco ip phone in sccp.
Using chan_sccp tge phone can log in and has line tone. i could able to call from cisco ip phone my soft phone But the problem is that it is not able to receive calls. i have more ip phones with me but all of the same i think need some configuration.
please update me in
Any help would be apprecieted.
Re: cisco ip phoe
Is the phones registered to CallManager or CME?
if CM, then it could be because of partitions and Calling Search Spaces. PTs are placed on the line and are restricted by CSSes.
If it is CME, then it could be a configuration issue
Posted on Feb 13, 2008
0 characters
3 Points
No dial tone
Hi Richard,
May be your new Router is blocking the ports used by your IP Phone by default. Check with your phone service provider for Voice Port (Mostly SIP or H.323 or SCCP) and open that port in your router.
Oct 18, 2012 | Linksys SPA942 IP Phone
How to upgrade to SIP Firmware on Cisco 7945G
This process should work for you
Cisco Telephone Power Brick
Sep 08, 2012 | Cisco 7945G IP Phone
I'm experiencing a problem with cisco 7941 IP phone. here is the current condition of the phone: it has no dial tone, the programmable button is alternately blinking, the headset button has a steady...
can you explain me how is your phone connect to internet.
best on your Question its seems to me you cant hear a dial tone because of following one or more factors might apply
  1. you must log into the Extension Mobility service
  2. you must enter a client matter code (CMC) or forced authorization code (FAC) after dialing a number
  3. your phone has time -of-day restrictions that prevent you from using some features during certain hours of the day
Sep 21, 2011 | Cisco 7940 IP Phone
Can i make calls with a Hide ID? cisco ip phone 7960 series
You will need to configure this through whatever SIP gateway you are using, it is not configured through the handset.
May 23, 2011 | Cisco 7940 IP Phone
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
Want to migrate fom sccp to sip protocol for cisco IP Phone 7912
Here's a great little document from Cisco directly, called "Converting a Cisco 7940/7960 CallManager Phone to a SIP Phone and the Reverse Process"
Easy to do, just follow the step-by-step directions.
Jan 21, 2010 | Cisco 7912G IP Phone
Here is the manual on how to Configure CCME, and this will apply to your 7912G. :)
Apr 24, 2009 | Cisco 7912G IP Phone
CP 7941G issue
Try configuring CCM IP address either trough DHCP parameter, or Network configuration on the phone.
Oct 08, 2008 | Cisco 7941G-GE IP Phone
Inline power problem: cisco ip phone 7941G
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Mar 20, 2008 | Cisco 7940 IP Phone
IP 7920 & Asterisk
I believe I saw somewhere that the 7920 works best with the 4.02 version of firmware... only hitch is you can't get it unless you have a valid Cisco login with access to their voice stuff. You could see if your local partner could get it for you otherwise. Also, I think you need the cradle to upgrade the phone manually - otherwise you need a TFTP server set up and the proper keywords in the cnf.xml file. There is better info on about these sccp phones - god I wish they (Cisco) would release a SIP firmware for these things!
Nov 23, 2007 | Cisco 7920 IP Wireless Phone
Cisco 7910 IP Phone Logo
204 people viewed this question
Top Cisco IP Phones Experts
Kirk Augustin
Kirk Augustin
Jose Ma DM.
Jose Ma DM.
Are you a Cisco IP Phone Expert? Answer questions, earn points and help others
