Question about HP PhotoSmart 7760 InkJet Printer
How to clean printer ink marks on paper
WHEN PRINTING I GET A FEW STRAY INK SPOTS. HOW DO I CLEAN THE INSIDE OF THE PRINTER ?
  • 11,896 Answers
You can clean the jets with rubbing alcohol and cotton swab. Also a paper-clip will help remove any clogs.
They also sell cleaning kits, but I use rubbing alcohol and cottown swab
Posted on Jul 03, 2009
    Scholar:
  • 59 Answers
Take a Q-tip and Clean bith the Bottoms of the Cart's, and the Landing spot for them. if your using "refilled" carts. this is a common Problem,and you'll just have to deal with it
Copies of documents are not clear
Spots on copying: Chk is there any marks on flat bed glass?,clean flat bed glass with wet cotton cloth, allow it for dry.
Spots on printing: There is no particular reason for this issue. clean paper path with wet cotton cloth & allow for dry..
Mar 18, 2013 | HP Deskjet 2050 All-in-One Printer
The bottom half of the text is not printing (as if it's being cut off)
Your question does not tell me what printer you have so I will assume it a modern HP made after 2004.
HP Printers use a ink cartridge and this is connected by a tiny pipe to the print head that sprays the ink on the paper. Your problem is with the Print head and not the ink supply.
There is a remote chance that some paper felt or paper dust, or even a stray piece of tape has blocked the lower part of the print head. I assume that this is the black print head, so that is the head marked with the letters K Y (Black and Yellow) on most modern HP Printers. Try to clean this using the clean or clear functions found in the maintenance section of the Printer Software. If that does not do the job then follow the instruction to replace the print head but rather replace the print head use a clean cotton pad with a few drops of alcohol to gently clean the print head and replace it as per the instructions. If that does not do the trick then the bad news follows....
Because the lower part of the Print Head gets the most use (., and underlining all use the bottom part) its also the first part of the Print Head to fail. If you live in the U.S. or Canada the print heads are not expensive. Go out and buy just the Black (K Y) if that is 80% or more of your printing use. If you are doing a lot of color it pays to buy the two heads together in one package.
Oct 16, 2010 | HP Office Equipment & Supplies
Printing but blanks
did the print out improve after your clean the head?
If all fails, try this last method.. take out all the ink and switch on the printer, when the printer detected no ink, it will ask you to insert the ink cart. Put back the ink cart and let the printer do ink charging.. pls make sure there is ink in the cart else it will damage the head.
After the ink charging, print a nozzle check and see if there is any improvement.
May 25, 2010 | Brother MFC 240C All-In-One InkJet Printer
My printer may need a cleaning. some lines are
run the printer configuration to allign your print head and clean it up. also check your ink level and i hope the ink is not drying up too cos that could cause it too
Jul 15, 2009 | HP DeskJet 6840 InkJet Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Won't print or copy (looks like it's out of ink or cartridge is jammed)
if you have the program of printer install to your comp ? then run the maintenance program , that will CLEAN , ALIGN , AND PRINT A TEST PAPER , AJ
May 08, 2009 | HP OfficeJet R80xi All-In-One InkJet...
Dark spots on the left side of the paper
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Mar 22, 2009 | Lexmark E330 Laser Printer
Getting spots on photos
I pulled out the cartridge that was causing the spots, dabbed at the small pool of ink that collected with a very soft paper towel, re-cleaned the print heads and that seemed to solve it...
Jul 11, 2008 | Epson Stylus 1400 InkJet Photo Printer
Dirty Cartriage or Printer head
you should clean the printer head or cartriage
Aug 31, 2007 | Lexmark Z715 InkJet Printer
HP PhotoSmart 7760 InkJet Printer Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
