Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Switching my hayward pool pump from 230v to 115v. I was told i could just move the jumper, line up the arrows for 115 and be fine but my gfi keeps tripping out?
  • jcv2273 Jul 05, 2009
    i changed the motor config,moved the jumper down 1 prong and lined up the arrows for 115v, now i get nothing gfi keeps kicking out??
  • Craig Butler
    Craig Butler May 11, 2010
    You changed the circuit feed to 115 volts? You changed the motor config to 115 volts?
    President:
  • Hayward Master
  • 1,378 Answers
Setting the pump for 115V wont by itself cause the trip. There is either a ground in the circuit or the GFI is bad. You may want an electrician to test any further than this.
Posted on Jul 04, 2009
Pool motor factory wired for 230v.need to change to 115v
take off back panel of motor if a switch turn to 115 volts or 120 volts what ever choice they give you if no switch see side of motor it will show you on low voltage to move the brown and white wires
Apr 27, 2013 | Pentair Whisperflo 3/4 Hp 115/230v
Hayward super II wiring
move so both terminals are used sometimes they don't line up put on 220 then move to other position
Jul 24, 2012 | Hayward Super Pump 1 1/2 - Hp for In...
I just installed Hayward 1.5HP inground and it tells me that if i use the 115v to use a 30 amp breaker - and when i left the 230V button positioning inside the back of the pump and connected with a 14 ...
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
Jun 05, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
The pump comes factory set for 230v. Power to the motor is 115v so I switched the jumper as indicated. The jumper is set on 2 posts with an arrow pointing to 230v. I moved it to 1 post and the arrow now...
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
I am replacing my Hayward 1 HP superpump. The old pump had the 230/115 conversion plug on line 1. The new pump has it on line 2. Do I jusst connect the 115 v(hot) wire to line 2? That would be oppisite of...
It will not matter where you put the hot and neautral as long as one goes on line 1 and the other on line 2. Just be sure to reset the voltage indicator to read the 115V like before and your all set.
Oct 19, 2009 | Hayward 1.5hp 230v 2 Speed Uprated Super...
It the line terminal the hot (i.e. Black ) wire
If I read your question as "Is the black wire the 'hot' line" then yes, it would be, IF your line leads are wired to code and we are talking about 115V.
Oct 14, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Going from 230v to 115v on Super Pump
open back you will see the bars to hook to it should show which is the right side 3wire only for 115
Jul 12, 2009 | Hayward Pool & Spa
My motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
Wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Jun 13, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
1,395 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
