Question about Toro Lawn Mower With Toro Power Tools
Toro gts5 leaking gas
I have a Toro gts5 that I have not used for 5 yrs. I tried to start it and smelled gas. I looked like it was coming from behind the filter. I removed the filter and saw the gas leaking from the small hose comming out of what I think is the filter. There is a small hose coming out from the filter also. I think somthing is missing that attaches them. Any ideas out there? Thanks
4 Suggested Answers
vincob
  • 718 Answers
SOURCE: Looking for a service manual to repair Toro Super Recycler GTS5
Try jacks small engines online!
Posted on Nov 25, 2009
SOURCE: what is wrong with a Toro GTS5 that starts well
Have a Toro GPS5 600 lawnmower. Starts with Choke on, but dies if you move off choke. Also, runs fast and slow when blade engaged. I heard carb for this unit are no longer available. Help
Posted on Aug 02, 2010
  • 2926 Answers
SOURCE: Toro lawn mower starts but
The engine is starving for fuel. At this point I am assuming the spark plug is clean and not fouled, and the air intake cleaner is not clogged. The idle jet passage most likely has a blockage, preventing fuel from reaching the combustion chamber. Priming the engine while it is trying to run is forcing fuel to the engine instead of the fuel vaporizing and flowing to the engine.
Posted on Oct 14, 2010
Toro lawnmower Wiil not start
Remove carb float bowl. Clean bowl. Observe float bowl screw, look for hole thru bolt, if present use thin wire to clean out. Float should be hanging freely and gas should be flowing, raise float gas should stop. Pinch off gas line or use shut off valve. Remove pin from float, remove float and needle meter. Use thin wire to clean out passage were meter needle is inserted, wire should pass thru to behind choke. Replace float & meter needle. Replace float bowl. Pull rope half way several times. Inspect primer bulb for cracks or leak. Try to start, may take 5 or more pulls to prime.
Jun 04, 2012 | Toro Super Recycler Super Bagger Lawn...
Starts and runs great(when engine is cold).\r\nafter 15 mins the engine dies. will start up again, but will only run about 5 sec. and then dies. toro super recycler 5.5 hp GTS5
I would check the gas cap. If the gas cap is plugged or pieces missing from inside it will not allow air into the tank and the fuel will not flow properly to the carburetor. Just loosen the cap and try it, if it does not change check for dirt in the fuel line.
Jun 15, 2011 | Toro Garden
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
I had a similar problem. I'll bet I took off the carb. 5 - 6 times and cleaned it with no success. Very fustrating! One time while checking the fuel level I accidently left off the gas cap, I started it and while running I put the gas cap back on and started to mow and about 10 seconds it died. I thought could'nt be! So I loosened the cap, restarted and it kept running. Any way the small vent hole was plugged. Thats my story!. Good luck.
Aug 20, 2010 | Toro Lawn Mower With Toro Power Tools
May 16, 2010 | Toro Lawn Mower With Toro Power Tools
Totr model #20479 GTS 5 motor, when you push prime
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Nov 16, 2009 | Toro Lawn Mower With Toro Power Tools
Toro GTS5 5.5 HP will not start
after attempting to start a few times;remove the spark plug and, check it if it is wet the engine is flooding dry the plug and, reinsert prime once and, attempt to start
if the plug is dry check the fuel filter
ground the plug while starting to check for spark
Sep 14, 2009 | Toro Lawn Mower With Toro Power Tools
I have a gas smell that seems to be coming from engine compartmen
you HAVE a gas leak, the best way for this problem is to use your senses of smell and sight.
Look for gas leaking at the same time smell for the strong smell of gas and locate the area.
Aug 11, 2009 | Toyota Camry Cars & Trucks
Toro GTS5 600 has not been used for 3 years, it starts on choke with a spray of engine starter then stalls out when choke removed Jim Slezak slezakj@yahoo.com
You will need to buy a carburetor kit and replace all appropriate parts. Use a Den Tek Brush,(http://www.shopping.com/xPO-Lustrasilk-Lustrasilk-Cholesterol-Shea-Butter-Mango-20Oz-Bonus), to clean the small portals in carb.
Jim
Jun 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
187 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
