Question about Garden
Lawn mower won't start
1 year old lawn mower won't start. Started first pull after long winter. I have mowed the lawn twice now the mower won't start.
  • 11,896 Answers
Carb is most likely gummed up and will need cleaning. Anytime a gas motor is store through a season, you should use a product called "stabil" in the gas to prevent gumming up. Also check that there is a strong spark coming from coil. To do this, remove spark plug, hook it up to the coil and set it on motor block and pull it over. You should see a strong spark. If you don't see the spark, then either the coil is faulty or the magnet from coil to flywheel is not getting good contact.
Posted on Jul 03, 2009
  • 3,600 Answers
Dirty air filter or dirty or plugged fuel filter on the end of fuel line.
Take Breather element off,and try to start it Then or if it starts that way cut it off and replace the breather and if it doesn't start You May need to change spark plug also, As if You have flooded it, Gasoline will kill a spark plug
Mar 27, 2013 | Garden
Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Jun 07, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Cub cadet 1515 won't start
I just had the same problem. I installed a new spark plug, sprayed some starting fluid in the engine and it started right up. I mowed my entire yard, and my neighbors yard with no problem?? I'll post more next mow and let you know if it has fixed the problem!!
Apr 29, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
Nov 30, 2017 | Simplicity Vacuums
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
Aug 21, 2009 | Garden
Suddenly no compression on Toro walk behind
yes the shear pin will throw the timing off.check it anyway it might be ok but then again you ever know.check for fire coil should be at 010.from frywheel it might slip check compresstion anyway with gauge then valve gap need manual for this if ohv check pushrods this could make bad compresstion if one is bent.let me know want you find out ok
Jul 24, 2009 | Garden
CRAFTMAN LT 1000 no reverse
if it has a reverse belt it could be broken or sliped off the pulley
May 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
224 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
