Question about Maxtor Hard Drive
No comp/laptop will pick it up and it just keeps beeping
I dont know what happened to my laptop but it worked last time i used it now when i plug it in my laptop or computer it doesn't even pick it up and when i turn the hard drive on it just keeps beeping, is there anyway of getting the data off at least?
    President:
  • 1,015 Answers
You could remove the drive from it's case and try installing it as a slave drive in your computer to try and get any files off the drive. If the drive is dead you will need to send it to a recovery specialist but that will cost some money.
Posted on Sep 21, 2009
Besides the box with the red X id like to add i was trying to clean up my laptop, and i deleted something that i wasnt suppose to and now imunable to play movies. Both happened at the same time
If this only happened within the last day or so, do a system restore and go back to the day everything was working
Start>All Programs>Accessories>System Tools> System restore and pick a date..make sure the laptop is plugged in to wall socket when doing this and once the restore starts, leave it alone..dont touch until its finised..Has to be plugged in because if it stops for lack of power etc in the middle, it will be screwed for good
Mar 11, 2013 | Computers & Internet
My comp starts very very slowly and picks very slowly whenever im doing anything
When was the last time you've used it properly? If it worked before then you may try " System Restore" are you using XP or windows7?
Jul 05, 2011 | Computers & Internet
When the laptop turned on, it's keep beeping all
Sounds like you have a stuck key, When the computer is off brush your arm across the keyboard a few times or try to find the stuck key and use a tooth pick to pop it up. Have you spilled anything on the keyboard?
Jun 05, 2010 | Toshiba Satellite A25-S279 Notebook
Cant get cruzer to down load
well many off name brand flash drives have software that need to be download enable for it to work other times u may need to go to the computer icon and double click and it will show the devices that are connected to ur comp and lastly u may have the settings to where it blocking devices from connecting. i dont think u know how that works so u probally didnt change it.
Dec 31, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Keyboard wont work.
i had the same problem and called hp i was told to turn off my notebook and unplug the charger from the notebook take the battery off and hold down the power button for 30 seconds then reattach everything my keyboard started working again. i was told this happens because i donot let the battery die on my laptop or i keep it plugged in all the time which is true the notebook has to much static and the keyboard stops working. hope this helps
Feb 15, 2009 | HP Pavilion dv2715nr Notebook
Problem During Boot-Up
several things it could be but im going to look at the obvious the battery and cord hook up
laptops when plugged into contstant 120 power the battery is supposed to go into stand by mode and shut battery off so power dont leak into battery
if you have low battery with it plugged into 120 the comp will still think the battery is powering the laptop if battery dead then comp shuts down lack of power
other thing is somehow you caught a virus that reboots comp from dos screen mode
the main thing i always ask is what was the last thing that happened before it did what its doing now
example= was there a power surge pop up screens ect.
May 09, 2008 | Toshiba Satellite A75-S231 Notebook
Worked first then boot error now comp wont pick it up
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Jan 31, 2008 | RCA OPAL M4001 MP3 Player
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Maxtor Hard Drive Logo
165 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
