Home | Canon | DR-5020 Path-Through Scanner | Canon DR5020 E21 error
Canon DR-5020 Path-Through Scanner
Problem for Canon DR-5020 Path-Through Scanner
By carywoods on Jul 03, 2009
I have an old Canon DR5020 that is giving me code E21 on power up. It may briefly flash an E22 as well. Popping off the panels I find there are several blinking LEDs. Of the 3 visible boards I have back LED101 blinks slowly, side LED1 blinks rapidly, and top fold up LED1 blinks rapidly. I have tried replacing the Mainboard from another DR5020, but same error. Any ideas?
Best Solution
posted on Jul 04, 2009
Helpful)
mohanchennai
Rank: Wiz  Canon Expert
Rating: 81%, 204 votes
Canon Scanners are reliable. Canon has chosen error codes logically, 'P' os Paper related, 'C' os cover related, 'E' is Engineering Support related.
E21 is Document Motor Trouble. E2 is Separation Motor Trouble. Check of connection and load or you may to replace motor. Try connecting the motor to a different location and if the error is same, probably there is no motor fault, if it changes then it definitely motor fault. As a last thing you may need to change the PCB on the side.
S. Mohan, Chennai, India
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Canon DR-5020 Path-Through
Questions and Unsolved Problems for Canon DR-5020 Path-Through
Do you recommend Canon DR-5020 Path-Through Scanner?
Answer
Answer
driver for Minolta dimage dual scan F-2400 XP
Answer
epson perfection 660 read image data failure code [ffff:0024]
Answer
need a driver for GOTEC vision 600 dpi scanner for vista 64bit computer
Answer
Trying to scan from Brother MFC-8440 flatbed into Mac mini OS X version 10.5.4. Opened Image... (More)
Answer
Auto Feed crumples paper. It's hardly been used, so it does not have much wear on it.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon DR-5020 Path-Through...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 455
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
