Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
The clean water fill will not shut off and water overflows from the dishwasher onto the floor. We had to turn off the water supply to the dishwasher to get it to stop.
  • ferro_mesarc Jul 03, 2009
    The water ran after we pressed the Cancel button (it ran while the dishwasher was draining) and continued to run even after we had opend the door. The only way we got it to stop was to shut off the water feed to the dishwasher under the sink.
    President:
  • 1,185 Answers
Fill valve is shot , new one required
Ps
Does it still run when you remove the power if so the above applies
If it shuts off then the problem sits with the pressure switch
Posted on Jul 03, 2009
  • Tom
    Tom Jul 04, 2009
    The fill valve has stuck in the open position
    Could be dirt in the diaphram
    Only solution is to strip it out and see if it can be dismantled for cleaning or is a sealed unit
How do I stop my dishwasher from filling up with water when not in use?
get the inlet valve replaced , or turn the water supply line off when not using the dishwasher .
Aug 27, 2016 | Hotpoint Dishwashers
Our Miele DW just keeps going through cycles constantly and will not shut off on its own. It has gone all day. When we turned the dial manually to "OFF", the water keeps filling until it overflows the...
hi,
sounds like a faulty electronic unit as i have seen this before where the unit continously fills with water.
you will probably need a service call to repair the unit unless you are happy to fix it yourselves. have a chat with Miele directly as they are very helpful
Hope this helps.
Jun 20, 2010 | Miele 24 in. G865 Built-in Dishwasher
I have a Bosch dishwasher model SHU66. Clean water slowly pools in the base when the dishwasher is not in use. We need to drain the DW every 12 hours or water will overflow onto the floor. Is this an isue...
IT SOUND LIKE IT IS A WATER VALVE ISSUE.DRAIN AND CANCELTHE MACHINE FIRST THEN TRY TO SHUT OFF THE WATER GOING INTO THE MACHINE PROBABLY UNDER THE SINK. SEE IF THE WATER IS STILL COMING IN TO UNIT. IT SHOULD NOT BE. THEN TURN ON WATER IF THE WATER STARTS TO FILL MACHINE THEN CHANGE THE WATER VALVE.
Mar 27, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Water keeps filling after shutting off machine. Overflows onto the floor. Please help!
Most of the time the problem is just the opposite of yours and the dishwasher will not fill...
This tip is about the dishwasher not filling, but the problem is still the same, only your soleniod valve has dirt under the plunger and it will not shut off. This tip will help you find it and help you to replace it.
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
Heatman101
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
New Whirlpool Dishwasher filler overflows.
New Whirlpool Dishwashers will NOT accept the same "volume" of water that was desired by the same products of 25 years ago. Therefore the old 3/8" ID copper supply is too large and will overflow the tub filler/aireator (out the air vent holes). I just installed a new dishwasher supply kit consisting of a new 3/8" OD stainless braded hose with an ID of about 1/4". This delivers less volume than that recommended (in the installation manual) and therfore does restrict the flow a bit. However, the flowrate is adequate and the new dishwasher now works perfectly with no water overflow on the floor . . .
Dec 26, 2009 | Dishwashers
Whirlpool duet washer fills with water when not running
one of the control valves (hot or cold) is not closing the water supply, most likely leaking so the electronics are good. one of the valves needs replacing, but if you dont want to spend the money just shut the water supply off at the water supply taps.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water is full and won't shut off dnby ddw399w countertop dishwasher
Hi, There is a water level switch in the d/w. located in front corner. You can move it up and down while listening for a clicking noise. Sometimes soap will gum them up so they don't move. when it is overflowing, will the water shut off if you turn the machine off or do you need to turn the water off at the faucet?
Please let me know so that I can assist you further.
Thanks
Vic
May 25, 2009 | Danby 22 in. DDW399 Free-standing...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
198 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
