Question about HP Computers & Internet
HP Pavillion a520n desktop will not power up. We just moved to a new house and something must have happened during the move. There is a blinking light on the back of the PC. Power button does nothing. Is there a reset button or fuse or something like that?? I can not find my manual to help myself. Thanks
    President:
  • 1,185 Answers
Remove the power first then:
Take the side panel off and make sure that all of the connectors are secure in their sockets
It is possible that the machine was bounced and the power connector from the PSU has come adrift .
Check the wiring from the front panel power on/off switch to the push on connectors on the Motherboard
Go onto www.hp.com and download an installation manual for the machine or look at the Motherboard when you have the cover off and go to their website and do the same thing
Posted on Jul 03, 2009
Pavillion a520n overheats and reboots. Fan on CPU runs during boot up then shuts off. Starts again when reboot occurs. Suspect thermal sensor not working. Is it in the fan or on the motherboard?
On motherboard. Please, make sure all fans are connected into motherboard.
Some fans can't plug in into the board at all. So, you can ignore those fans.
When you go to Bios to check thermal condition, if a fan is not plug in, you can see 0 degree. 0 degree dosen't cause the shutdown problem. (That's why you can ignore)
Then check which fans are causing problem, first. (If you did and found the problem, go next.)
Replace fans AND clean those dust!
If the problem remains, then replace its case to steel one.
Well, usually a lifetime of CPU fan is pretty longer than others.
Just in case, one more thing, if the thermal condition is OK, then the shutdown problem is caused by something ales!
May 26, 2011 | HP Pavilion A520n (DW233A#ABA) PC Desktop
I have a yellow blinking light on the power supply of an HP model A000 Pavillion computer. What does that indicate?
if your power supply light is blinking and wont reset that means a component in the power supply has failed or fried or something unknown happened and will have to be replaced
Dec 13, 2010 | HP Pavilion A730N (PJ510AA) PC Desktop
HP Pavilion A520N will not power up. Green light
Which light?? the network light?? Do you get anything when you press the power button if not it is most likely the power supply since the motherborad is still showing power also may be cpu!
Nov 17, 2009 | HP Pavilion A520n (DW233A#ABA) PC Desktop
Hp Pavillion a420n blinking light
Hello.
Is the computer still its power ? if the pc has its power then try to switch on without the memory. if the system beeps means that the mainboard and processor is good. However, if the pc has no power at all then first check the power supply.tell me what happen i give you more troubleshooting.
Mar 25, 2008 | HP Pavilion a420n PC Desktop
Power Outage - PC will not Boot up
nope...you might have lost any combination of these items:
A. Power supply
B. Motherboard
C. uProcessor
D. Memory
This is a good reason why folks use UPS devices. Hope this turns out for you.
Mar 13, 2008 | HP Pavilion A520n (DW233A#ABA) PC Desktop
No Power!!
Double check the switch in the back of the pc on the power supply. If their is a switch, you can try it in both positions. It is possible their is no switch, older compaq's are iffy. The switch will be black. Also check the 110/230 switch. I don't know what country you live in, however you may need to make sure that switch is in the appropriate spot. 110 for USA and 220/230 for UK
Also, try unplugging your pc. Let it set for about 1 minute. Plug it back in and try again.
Oct 11, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
247 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
