Question about Garden
Have Yard Machine (model 12B264c062) 22inch B&S 4 HP mower. Carb does not have fuel bowl with float and needle valve. Engine starts easy enough but will not run at proper RPM or smoothly. checked and confirmed all igniton parts are working properly. Engine will run at proper speed JUSY AS FUEL TANK is running out. HAs to be a fuel flow problem - acts like floar out of adjustment etc. Appears that tank has some kind of reservoir for fuel metering, but can't figure out problem. Again has to be fule flow as engine races back to normal RPM as it runs on last 20 -30 seconds of fuelin tank????????
  • davidwashley Jul 03, 2009
    Hi thanks very much for the reply. One thing I forgot to add is that after determining my problem was definitely fuel related, I began trouble shooting in the typical ways like restricting air to carb while engine is running (like a choke valve would do) to see if rpm would improve/stabilze. It was just the oposite. Theonly way I could get the engine to run at normal (smooth) rpm was by blowing air into the carb with my air hose. So I relaized there was too much fuel going into the carb. Also while loking for info on the net I discovered the same area of concern as you pointed me to - this diaphram. Some of the discusion I saw about diaphrams though was where engine was not getting gas. Again in my case its too much. Will burn a tank in half the time as usual in its current state. So back to your recommnedation - with these two addtional diagnosis you feel like I need to replace the diaphram/ Tahanks again, David
    Sergeant:
  • 296 Answers
Hi
There is a small diaphram on the side of the carb that simply wears out. It's rubber coated mesh and the rubber coating breaks down and it stops pumping fuel into the carb. Sometimes you can run with the choke on partially, but it will burn 10 times the amount of fuel and cause more damage to the engine itself. I think it's about a $10.00 part.
OR
have the carbureator rebuilt, ethonal breats down into a gum that cloggs passages in carb need to be very clean to run properly. use stabil (fuel additive) in outdoor equipment gasoline and Sea Foam is also a exelent fuel additive .
hope this will work for u
regards
Posted on Jul 03, 2009
Why does gas pour from my air filter
Bad float. Remove bowl from carb. Replace float and meter needle valve.
Jun 03, 2013 | Mtd 22" Yard Machine Push Mower
How do you clean the carb
usually theres a small bolt under float bowl of the carb. remove small bolt and remove lower bowl to empty out - careful not snag the float or let float drop to far, the needle valve is attached to the float. Once bowl is empty you replace the bowl- the gasket is rubber and the one around the small bolt is a thin brass washer all reusable. To make sure the bowl is back on right make sure the shallow end of the bowl is directly under the needle seat area so the bowl won't restrict the float movement
Mar 27, 2013 | Yard Machines 158cc Push Lawn Mower #11a...
This is not a rider mower its a push mower. I pump bulb engine starts and then quits
when this happens, the engine only runs long enough to consume the gas you manually put into the carb. The engine dies because the main jet of the carb is plugged or there is water in the fuel system. repair by dumping old fuel from tank, then remove float bowl on carb. this will drain remaining fuel in carb and give you acess to the main jet as well. Main jet will be located in the protruding part of the carb that sets as the lowest part in the float bowl. locate the jet either on the side of this protruding area or set into the bottom of the protruding area. use a thin wire like a guitar string to run thru the small hole in the center of the jet. then squirt a little wd-40 thru the hole and check visually to make sure the jet is clear. there also could be a problem with the float or needle valve that allows fuel to enter the carb and regulate the fuel level in the float bowl part of the carb. check this by letting the float drop while bowl is removed and gas should trickle down from the needle valve, if it does, then hold the float to the top of its travel but do not force it beyond the stop. fuel should now stop trickling from the needle valve. if it does not stop, then you probably have a little debris clogging the needle valve preventing it from closing completely. this usually causes a flooding condition. By your description, this is not the problem as your mower slound as it is starving for fuel. if no gas flow from needle valve while float is at the bottom of its travel, then you may have a clog in the fuel line, filter or in the tank where the fuel line connects to it. remove fuel line from carb and fuel should flow freely from this hose. if not, check for clog in the fuel line-fuel filter system. hope this helps! oh y, the last steps require a little fresh gas in the tank!
Aug 19, 2012 | Mtd 22" Yard Machine Push Mower
When trying to start fuel spits out of the carburator
Remove carb float bowl. Clean bowl. Get model no. of engine and get new float bowl gasket set at mower repair store. Ensure float drops down freely with float bowl removed. Push up on float to stop fuel flow. If not working properly replace float and meter needle.
May 31, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Model 42a707 engine spitting gas out of carberator
Fuel needle leaking in the carb, remove the float bowl, check the float is moving freely, clean away any dirt, if no better replace the inlet needle.
May 06, 2012 | Yard Machines Garden
The engine started then few minutes later died after cleaning the carburator,float bowl assy, air filter .and fuel lines re assembled the engine and fuel is leaking from air filter and primer
You may need to also thoroughly clean the small holes in the brass bolt that holds the carb bowl on...holes at botttom and across the middle where there are no threads. Don't use anything that will enlarge these holes as this bolt is also the main jet of the carburetor.
Jul 13, 2010 | Mtd 22" Yard Machine Push Mower
My 2007 Toto recycler rear drive starts then stops after few seconds, has gas, seems like gas isn't gettin through .
Underneath the carb there shoul be a bowl screw head, usually 1/2in or 13-13mm. Loosen bowl screw a little, fuel should come out. If so, pinch off the fuel line to the carb from the gss tank or empty the gas tank. Remove the screw from the carb bowl. Inspect the hole inside the screw & the hole or holes thru the screw near the screw head for debris. Spray with carb cleaner & tap on hard suface to dislodge debris, you may have to use a small wire to clear these orfices. Make sure the float is free to fall down. You can remove the float, carefully as there is a spring & a needle valve at the back of the float in the middle where it is hinged. Ensure the needle valve is clean & the tube to the carb is cleam. After cleaning everything & clearing any clogs re-assemble carb & try to start.
May 13, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Briggs & Stratton 6hp yard machine with 21inch cut. Not getting fuel. I replaced a bad fuel line and now no fuel! If I take the air filter off and spray fuel into the carb it runs until I quit.
The fuel bowl needs to be removed and a new float and needle needs to be installed. The float "floats" in the gas bowl raising the needle, letting fuel into the carb. The repair kit cost about $5 and easily replaced. The float is attached with a pin and the needle fits on the float.
May 12, 2010 | Mtd 22" Yard Machine Push Mower
I have a yard-man 6.75 hp,190cc self-propelled lawn mower, model 12AV566M055. While cutting grass, I hit a large patch of grass (no debris) in which the mower choked out. Now the mower will start but won't...
This is how to clean the fuel passages in the carb for a honda type OHV engine.
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it is not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement and fuel flow.
7. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions. Reassemble connections.
FUEL FLOW IS GOOD
8. BEFORE you install the float bowl inspect the bowl nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it. (carb cleaning 101)
Thanks for using FixYa.
Kelly
If the above does NOT apply to your engine then please respond with the engine type model number off of the air shroud just above the spark plug. ALL of the type model numbers will be needed. Also in some cases the serial number.
Apr 08, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
Honda gx 620 20 hr.gas is filling the crank case
needle valve on carb has trash in it and is not stopping fuel flow when bowl is full.remove bowl and work float to flush trash out and you can remove float and remove needle valve and replace.
May 08, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
281 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
