Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
My hoover spin scrub machine has stopped scrubbing. It still dispenses and pulls up the water, but the brushes don't move. I've checked the on off button for brush control and cycled it to off and back on, but no movement out of the brushes.
There is a filter on the front right hand side of my F5871-900 Hoover. If you remove the plastic covering and clean that filter (wet finger may do), you're Hoover will begin spinning again!
Posted on Jul 06, 2009
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Does the Hoover F5835-900 have spin scrub brushes?
No. The F5893-900 has a brush but it is just a straight brush and does not spin.
Jul 18, 2010 | Hoover F5835900 Upright Steam Vacuum
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Help. The brushes on my Steam Vac Spin Scrub
If you don't have the user's manual for the machine, here it is:
www.thinkvacuums.com/pdf/uprights/Hoover_F5914900.pdf
Check your system for any obstructions that could possibly causing the problem. Also, remove the brushes and see if there's a problem between the brushes and the motor.
Aug 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Spin-scrub brushes do not spin
hello. there is a little window by the brush control. if you open it up, you can see that there is maybe some lint covering it. scrape that off, and try again. make sure your lever is set to brushes and realease the handle release. if this doesn't work, then you probably have a problem with your gear box. this can only be serviced at a repair shop. I hope this helps. Let me know! Thanks, Renevacdoc
Jul 23, 2009 | Hoover F7431-900 SteamVac Vacuum
Water and cleaning solution will not dispense unless I hold it for a while
check the belt on the pump it should be a cover on the side pull the belt to the pump if its glazed replace if not then clean the shaft old soap may be on there.
Oct 03, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover all terrain dual v spin and scrub 12 amps
All of the hoover cleaners use air to spin the brushes the air intake is probably clogged. There is a Little clear window on the top of the machine pull that off and underneath is a little screen clean that out and that should fix your problem. If you need any parts or cleaner for your machine visit www.stevessewandvac.com
Aug 12, 2008 | Vacuums
Hoover model F8515 won' t **** up any water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=703954
Hoover Model F8515 won' t **** up any water
posted by kevingao92 on Jun 24, 2008
It could be in reverse do you have any tips
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. the Hoover Model # F8515 works on the pull back to pickup the water and on the push forward you can dispense extra water or solution and the brushes will still scrub but on the pull back it dispenses, scrubs and also picks up the water all in one sweep, if not then contact you local vacuum dealer in your area, check the owner’s manual for the trouble shooting guide and or call the Hoover Factory cust serv @ the information listed below.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Spin Scrub Brushes won't turn
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Jan 13, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
516 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
