Question about Behringer Pmp3000 16 Channel Audio Mixer
Me too!!!!! how repair it?
  • Behringer Master
  • 5,603 Answers
Repaired a PMP5000. Several transistors, a chip, diodes and resistors all destroyed by arc-over in power amp area. Faillure burned the board and had to cut the cancer out and jumper around blown circuit traces. Lot of work and takes great care to restart to avoid blowing components due to bad ones that repair missed.
Posted on Jul 26, 2009
I Have a Technics PR-305 Digital Piano that I have and really like. I went to play on it on October 12th. Certain notes with different chords weren`t sounding.
it can be repaired or replaced if the boards are still available
Take it to an authorized service to have it repaired and failing that some shops that repair micro wave ovens have the technical ability to repair items of this nature
may be a good radio technician or radio repair shop could also do the repair as it is basically an electronic ( wireless/radio) that is controlled by keys
Oct 14, 2015 | Music
Some keys are not functioning properly and some of the keys have been breaking the chord rythms
This repair is probably beyond the DIY class of repairs. Best to take to a shop for repair.
Jun 08, 2011 | Casio LK 230 Lighted Personal Keyboard, 61...
Hi I got PMP3000 and all of a sudden in the program smoke came out of the unit and I unplugged the Mixer...I have given it to repair and they saying the Main power SMPS has blown out..they charging too...
Sorry... you likely have one of the power amp channels bad as well. One does NOT replace the power supply, instead repair it. You need a competent repair shop. I can tell you what parts are blown on the supply. They cost about $30 max for parts to repair the power supply. There usually is about $15 of parts blown on the amp that caused the problem and significant labor to repair the amp portion. If the smoke was dark or heavy, it was likely from the 0.03 ohm metering resistor on the bottom of the amp circuit board that caused the original problem. If one replaces the power supply and turns power on they will find one side of the amp doesn't work and MAY blow the power supply again immediately. I have repaired several of these units and have walked others through the repair sequence as well. You can contact me directly by email for more info if you need it. Unless you can find a competent repair shop that replaces components, including work on surface mounted boards, the cost of the module parts AND availability will preclude repair. The amp module is another $155 after the power supply is repaired if a channel is bad and one chooses to replace rather than repair.
Apr 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Is there a Yamaha school of instrument repair? Pianos, Keyboards and Organs
Yamaha prefers to MAKE the instruments rather than conducting repair schools... they may have some very specialized schools for individual types when first introduced. With the situation in Japan right now such classes would be cancelled I am sure. Instrument repair is so specialized other than basic piano repair/tuning that you will find few if any courses. For piano repair you might want to search YouTube for videos. For organs and keyboards, detailed electronic knowledge and the service manuals are what we have to work with. You need both experience in digital and analog plus test equipment including oscilloscopes and signal generators as a start.
Apr 13, 2011 | Yamaha Music
Where can I take my roland juno keyboard to be repaired lost soun
juno, lovely instrument, try the synthesizer repair centre in london
Feb 06, 2010 | Roland Juno-D
Hohner 12 hole Chromatic, Super Chromonica. A # is " flat."
You can take it apart by removing the two screws, see if any of the reels seem blocked or obstructed by dirt, bits of dust, oxydation (greenish crystalline stuff) or similar, try to remove the stuff that seems to obstruct the reel with a medium hardness paintbrush (you might want to use some alcohol), but be very careful not to permanently bend or otherwise damage the reels, it will ruin the sound of the harmonica.
regards
Triarcuate
Oct 01, 2009 | Hohner Super Chromonica Chromatic...
I need to repair a sticky key on a P120. Is there a repair manual?
Call around to local music stores and ask about the closest authorized Yamaha repair center. If it is still under warranty, they should replace the keybed free of charge.
Here is a great website with the do's and don'ts about self keyboard repair. http://www.mikebarden.com/view.php/area/1/digital-piano-repairs-keyboard-repairs
Sep 17, 2009 | Yamaha Full-Size Keyboard
Burnt out my Boss BR 1180 How do I repair?
this is a job for an advance electronic repair tech...try the manufacturer..next a tv repair shop..then an Audio Install shop...if that doesn't work out..i'll personally try to fix it..for lest than anyone else..its probably the tranformer output circuit overrun..that part of the board or component wil have to be replaced...good luck
Jun 16, 2009 | Boss Micro BR Digital Recorder
Burnt out my boss BR 1180. How do I repair?
I'm not sure which entry will get to you, so... The likely defective part is the voltage regulator. This should be fixble by any shop that handles audio gear. No special test equipment or parts are required. The regulator circuit should be fairly standard and simple. Where are you located so I can recommend a shop? Dan
Repair bellows
I would suggest asking an accordian repair technician.
Mar 13, 2009 | Music
Behringer Pmp3000 16 Channel Audio Mixer Logo
113 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
